Help Bosch RA1166 Plunge base on RA1180 table - Router Forums
 2Likes
  • 1 Post By MT Stringer
  • 1 Post By Cherryville Chuck
post #1 of 8 (permalink) Old 04-03-2017, 12:52 PM Thread Starter
Default Help Bosch RA1166 Plunge base on RA1180 table
I cannot get the Bosch RA1166 Plunge Base Type P to line up with the mounting plate on the RA1180 table.
I have no idea what type of mounting plate to order but the plate that came with the table does not line up with the plunge base (black protective base has been removed from the RA1166 Plunge Base.
Thanks for any help.
Parks is offline
post #2 of 8 (permalink) Old 04-03-2017, 01:24 PM
MT Stringer's Avatar
To make the story short and simple, you need the fixed base to mount under the table.
Edit: Ebay has several. That is where I bought one.
http://www.ebay.com/sch/i.html?_odkw...+base&_sacat=0
Note: I have two complete kits for the 1617.
Parks likes this.
MT Stringer is offline
post #3 of 8 (permalink) Old 04-03-2017, 01:25 PM
It's common to have to redrill those plates to fit your specific router.
Parks likes this.
post #4 of 8 (permalink) Old 04-03-2017, 01:27 PM Thread Starter
Default Updated Pics
Here is what I'm dealing with.
Send help or Vodka.
Parks is offline
post #5 of 8 (permalink) Old 04-03-2017, 01:30 PM
like what was said...
you need the fixed base...
post #6 of 8 (permalink) Old 04-03-2017, 01:30 PM
Welcome to the forum.
You will have hell using a plunge base when it is mounted to the table.
Just bite the bullet and do it right. You can thank me later.
File Type: pdf Bosch 1617 EVSPK Router Combo Kit Description -small.pdf (442.3 KB, 54 views)
post #7 of 8 (permalink) Old 04-03-2017, 01:35 PM
Mike..
the new plunge base's springs can be disabled and adjustments can be made through the bottom of the base...
as stated.. the plunge base isn't meant for that table...
post #8 of 8 (permalink) Old 04-03-2017, 01:39 PM
Mike..
Still aggravating, and no micro depth adjustment. ..and no provision for adjusting from above the table with the hex key. Too much trouble for old fat guy.
And I can almost guarantee that after going to all the trouble of making the plunge base work, it wouldn't be 15 minutes before I would need to do some kind of hand held operation!
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
Wanted: Bosch RA1166 Plunge Base MT Stringer Woodworking Classifieds 4 07-14-2013 02:01 PM
Bosch Colt Plunge Base Ben in Cypress Texas Portable Routing 5 05-18-2013 10:10 PM
DIY Base Plate and Table bcskinz DIY and Renovation 7 03-25-2010 10:32 AM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 07:54 PM
