using router to plane and taper thickness of timber - Router Forums
 11Likes
post #1 of 13 (permalink) Old 04-09-2017, 07:05 AM Thread Starter
First Name: dave
Send a message via AIM to pinehunter
Default using router to plane and taper thickness of timber
A small piece of timber is needed for replacement of banjo fingerboard.
kp91, MEBCWD, TenGees and 3 others like this.
pinehunter is offline
post #2 of 13 (permalink) Old 04-09-2017, 07:34 AM
Gene Howe's Avatar
First Name: Gene
Pretty nifty.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 13 (permalink) Old 04-09-2017, 07:43 AM
kp91's Avatar
First Name: Doug
Nice router ski setup! Can't wait to see the finished work.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 13 (permalink) Old 04-09-2017, 07:45 AM
paduke's Avatar
Nice Jig I like my Trend router also. Did you make the skis or are they store bought
paduke is offline
post #5 of 13 (permalink) Old 04-09-2017, 08:07 AM Thread Starter
First Name: dave
Hi Bill the ski/frame is home made and easily constructed with DIY tools. The maximum drilled
hole diameter is 1/2" and the threaded items are limited to M6 and M8 sizes for standard bolts.
Regards dave
post #6 of 13 (permalink) Old 04-09-2017, 09:26 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
That certainly is another way to make router skis but constant sliding of the router along the rods is bound to cause wear.
My approach is rather different, as shown.
File Type: pdf The making of a set of router skis.pdf (1,001.8 KB, 98 views)
File Type: pdf Threading smooth rods for router skis without.pdf (517.8 KB, 97 views)
MT Stringer and TenGees like this.
Harry
harrysin is offline
post #7 of 13 (permalink) Old 04-09-2017, 12:31 PM Thread Starter
First Name: dave
Thanks Harry for your comments. I feel some misunderstanding exists. The frame is bolted
to the table and does not move. During cutting the router is stationary and clamped to the
horizontal rails. The sled is used to move the timber into the cutter and overlapping cuts are used
by moving the router along the horizontal rails. The two battens are used to restrain the sled when
feed directions are changed.
Rogerdodge likes this.
post #8 of 13 (permalink) Old 04-11-2017, 02:19 AM Thread Starter
First Name: dave
This is the fingerboard with the
fret slots lightly cut. Final cutting
will be done when fret wire is
chosen. The fretboard is for an
80 year old mandolin banjo with
originally a 13.25" open string length. To make measuring easier
with a metric rule this has been
slightly adjusted to 336mm
post #9 of 13 (permalink) Old 04-11-2017, 05:06 AM
hawkeye10's Avatar
First Name: Don
Is this mandolin going to be used to play blue grass? I sure hope so.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 13 (permalink) Old 04-11-2017, 05:33 AM Thread Starter
First Name: dave
Hi Don Blue Grass should be easy. looking forward to hearing Salt Creek and Arkansas Traveller.
Regards dave
