Top or Bottom Bearing - Router Forums
 8Likes
  • 5 Post By greenacres2
  • 1 Post By AndyL
  • 1 Post By MEBCWD
  • 1 Post By hawkeye10
post #1 of 10 (permalink) Old 05-03-2017, 02:11 AM Thread Starter
Default Top or Bottom Bearing
On a router table set up, what is the more common bottom bearing or top bearing?
Are there any pros on cons for each of the options.
I appreciate stock thickness will dictate the choice in some way.
Regards
John
John Charnock is offline
post #2 of 10 (permalink) Old 05-03-2017, 05:30 AM
First Name: Earl
On the table, I prefer top-mounted bearings with my pattern/template atop the work piece. That way any excess bit is below the table instead of sticking out, menacing my fingers.
edit--*I guess in buying, it might officially be a "bottom bearing bit" that i'm using upside down? This is why I use pictures to order from!!
earl
greenacres2 is offline
post #3 of 10 (permalink) Old 05-03-2017, 06:24 AM
First Name: Andy
In a table I'd definitely go with a bottom bearing (so the bearing is on top when inverted in the table) as Earl described, much safer.
Herb Stoops likes this.
AndyL is offline
post #4 of 10 (permalink) Old 05-03-2017, 09:43 AM
MEBCWD's Avatar
They do make bits with both bottom and top bearings and if you are having problems with tear out you can route up to the grain change and flip the part lower or raise the bit to use the other bearing and finish cut the part.
Look at this post and the pictures I added, read my post for an explanation.
http://www.routerforums.com/router-b...0-bit-use.html
Semipro likes this.
MEBCWD is offline
post #5 of 10 (permalink) Old 05-03-2017, 09:54 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
The bearing on the top as the cutter is in the table is the most usual way.
Any roundover bit will come that way anyway.
But then if its a straight sided cutter, you have full adjustment on how much cutting edge is shown.
The only cutters i use in the table with the bearing at the bottom are slot or comb joint bits.
sunnybob is online now
post #6 of 10 (permalink) Old 05-03-2017, 10:47 AM
Do you mean one like this?
https://www.amazon.com/MLCS-Bottom-B.../dp/B000LG98TC
Herb Stoops is online now
post #7 of 10 (permalink) Old 05-03-2017, 12:10 PM Thread Starter
Very confusing but I think I get it
J
post #8 of 10 (permalink) Old 05-03-2017, 03:26 PM
J
It is really quite simple if the router is hand held the bearing on the end of the bit is down so it is a bottom bearing.
If the router is in a table ,the bearing on the end of the bit is sticking up on the bottom of the bit , and the top of the bit is in the chuck of the router in the table.
Makes perfect sense.
post #9 of 10 (permalink) Old 05-04-2017, 02:52 AM
hawkeye10's Avatar
First Name: Don
It is simple but also confusing. Did I just say that!!! I think they should say the bearing on the (end) or in the (middle) or both. Would that help???
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 10 (permalink) Old 05-04-2017, 01:42 PM
what makes it more confusing is that when hand routing the template is on the top of the work and when table routing th template is on the bottom of the work with the same bit. or vice versa with the bearing on the other end. My guess is the routers were originally designed to be hand held, and shapers were for table routing.
Chili-grower building a wooden CNC router? Amiteur!! Jay-D CNC Routing 61 02-13-2020 02:01 PM
Maloof Inspired rocking chair build TwoSkies57 TwoSkies57 Gallery 235 07-13-2014 05:29 PM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 5 08-04-2012 04:07 PM
Top or bottom bearing? tdale Router Bits - Types and Usage 18 03-05-2012 01:59 AM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
