Help with pattern routing small job - Router Forums
 3Likes
post #1 of 11 (permalink) Old 05-20-2017, 02:24 PM Thread Starter
Default Help with pattern routing small job
Hi
I tried to pattern route this small item today, I could not prevent the bit from snatching the workpiece, I was working right to left.
Any ideas as to what I was doing wrong ?
J
Name:	2017-05-20 20.00.56.jpg
John Charnock is offline
post #2 of 11 (permalink) Old 05-20-2017, 02:34 PM
no start pins to rest the work against......
you started cutting on a corner instead of on a long side...
post #3 of 11 (permalink) Old 05-20-2017, 02:48 PM Thread Starter
I do have a starter pin which I thought about after the event, I'll give it a try.
If I don't start on the corner, how do I go back to it - left to right to finish ?
post #4 of 11 (permalink) Old 05-20-2017, 02:54 PM
Do like Stick said install a pin in table to rest piece against and start in the middle of th long side then hold tight to pin going around the corner.
Sometimes I use a Parallel clamp to hold small parts to route.
Sometimes taking light cuts help too.
Name:	Parrellel clamp.JPG
Herb Stoops is online now
post #5 of 11 (permalink) Old 05-20-2017, 03:00 PM
Originally Posted by John Charnock View Post
keep walking/feeding the piece around the bit till you get back to where you started....
post #6 of 11 (permalink) Old 05-20-2017, 03:07 PM
make sure you read this thread...
http://www.routerforums.com/guide-bu...all-piece.html
post #7 of 11 (permalink) Old 05-20-2017, 04:45 PM
Semipro's Avatar
First Name: John_*
Here utube video showing you the pin
whimsofchaz and Herb Stoops like this.
Semipro is online now
post #8 of 11 (permalink) Old 05-20-2017, 05:53 PM
Honored Member
First Name: pat
Small work will never hold on double sided tape, & it's dangerous.
The work can fly away at any time.
Vacuum, pins, or 2 small screws will give you some insurance.
Herb Stoops likes this.
Quillman is offline
post #9 of 11 (permalink) Old 05-20-2017, 08:50 PM
JOAT's Avatar
First Name: Theo
Which is the pattern? Top, or bottom, piece? I have routed pieces about that size before, always with my master (what others call patterns or templates) on top. My masters are two 1/2" plywood pieces glued together. I see you are using nails. I use nails also, but my master nail pilot holes are usually about 1/2" apart, and I would use at least 4 nails in a piece that size, and add more nails if it seemed to be shifting. The 1" master give me a solid grip, and I use both hands - being very careful about keeping my fingers away from that whirly part, shifting my hands very frequently, and taking very shallow, and short, cuts. I'm not had any issues with my method. However, what you picture is about as small as I will willingly go without some how clamping the piece.
Disclaimer: Just because I do it this way, does not mean I recommend you do it the same way. Different background, different experience, and all that.
JOAT is online now
post #10 of 11 (permalink) Old 05-20-2017, 11:58 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Thats small to have your hands near the cutter.
I use a micro jig gripper for small pieces. Loads of plastic between me and the blade, plus a good handle on which to press down as firm as you like.
Start from the pin and just go all around the item running right to left. But depending on wood type, you might not get it past the end grain.
I find rosewood to be so hard that the cutter chatters and breaks away however fine the cut, so I just finish that end grain by hand.
sunnybob is offline
Template Routing a Fairly Small Piece indnajns Guide Bushings and Templates 26 05-25-2017 06:26 PM
Small scale routing minicurios General Routing 20 04-22-2017 03:35 PM
Template routing small pieces without breaking rogtek Table-mounted Routing 15 09-15-2016 11:12 AM
Hot melt glue to hold small parts for pattern routing? rstermer Portable Routing 22 06-22-2009 09:05 PM
Pattern routing curves kak047 Jigs and Fixtures 6 11-03-2004 02:31 AM
