cnc router, almost - Router Forums
 1Likes
post #1 of 14 (permalink) Old 05-31-2017, 03:30 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default cnc router, almost
Just want to run this idea past all you experts.
I am trying to find a way of flattening smallish pieces of wood, quickly.
I dont want a cnc router as such, but would a very basic version of one act as a mini planer?
I have a sled mounter router, but it is packed away normally, so at the moment I have to assemble the sled and router, then spend a lot of time standing there trying to flatten a piece of wood that might only be a few inches by a few inches Pieces that are far too small to use a plane on. Lots of my time wasted.
So, would it be feasible to have a bench top cnc machine running all by itself while I got on with other stuff? not even interested in 3 d shaping at this stage, just to make it flat.
One other thought is to be able to flatten a larger piece by feeding a small plank through in stages. i'm not talking perfect finished surfaces here, just flat enough to able to glue the pieces into a sandwich.
No, I dont have room for any normal planer.
sunnybob is offline
post #2 of 14 (permalink) Old 05-31-2017, 07:27 AM
JOAT's Avatar
First Name: Theo
How about sanding?
JOAT is online now
post #3 of 14 (permalink) Old 05-31-2017, 08:12 AM
MEBCWD's Avatar
Most desktop CNC machines will take up as much room as a planer.
Remember if you get a CNC you need a computer to run it.
If you get the planer you could save yourself around $1,000 or more.
You could also build your own CNC and save a few dollars but still need a computer, you can use free software.
You could also buy a dedicated router for the sled so it is always ready to use.
MEBCWD is online now
post #4 of 14 (permalink) Old 05-31-2017, 08:33 AM
First Name: Gary
Bob, How about a hand plane?
gmercer_48083 is offline
post #5 of 14 (permalink) Old 05-31-2017, 08:54 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Hand plane requires skill which I dont have. What I DO have is arthritic thumbs making most hand tools painful to use.
Sanding I can do as there isnt any jolts to the hands, but Its very time consuming and I am not good enough to get the surfaces parallel and square. This is the really big issue, I need square in both directions.
I have a dedicated router sled. It takes time, its extremely noisy and even messier, and every time I set it up i just think there has to be a a better way.
Cost IS important, but ease of use and convenience is also a high priority.
I think a drum sander would be the answer, but they are almost as much as a basic cnc router and as I havent actually used either, i'm looking for your advice. Theres no way I'm going to build my own drum sander, i just cant be arsed with all of that, too many times I have bought machines before thinking they would be the answer to my prayers, and have mostly been disappointed.
Is it not possible to just set up a small cnc to cut a flat surface without all the thousand dollar programmes?
sunnybob is offline
post #6 of 14 (permalink) Old 05-31-2017, 09:01 AM
@sunnybob
Rather than the elaborate sled as demonstrated by HarrySin which requires that the router be mounted to it, why not something as simple as shown in the photo - it could be made out of wood rather than aluminum. As you are only working on smallish pieces, sitting the sled across two pieces of wood would be sufficient, and the router only has to be dropped in the sled, no "mounting" required. If the piece was badly warped/twisted, it would still require shimming underneath to stabilize it for machining - but the same would be required if you were trying to do the job on a CNC.
tomp913 is offline
post #7 of 14 (permalink) Old 05-31-2017, 09:05 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Tom, my sled is an mdf slab with the router mounted in the middle. As router sleds go, its accurate and infinitly adjustable, sliding over a home made adjustable tile base. It works, but I am really hoping for an improvement that will speed the process.
sunnybob is offline
post #8 of 14 (permalink) Old 05-31-2017, 12:13 PM
old coasty's Avatar
First Name: Bob
How about a jig to hold A belt sander belt side up and sand the pieces on the belt?
old coasty is offline
post #9 of 14 (permalink) Old 05-31-2017, 01:01 PM
vchiarelli's Avatar
First Name: Vince
Bob
For small parts I use a Delta 31-450C belt/disk sander. Bought this years ago for $100 and still going strong. Or if you have a regular belt sander you could look at Jay Bates design at this link:
vchiarelli is offline
post #10 of 14 (permalink) Old 05-31-2017, 02:47 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I have a 4" belt sander, its connected to my extraction and it is used a lot. Trouble is although it does make smooth sides I cant keep the wood square. Any serious sanding can result in wedge shapes.
Having done a lot more research today I think a drum sander would be what I want, but its way out of my price bracket.
I'm going to have to make up a sled for the lunchbox planer I have, so that small pieces can go through without any snipe.
sunnybob is offline
DIY CNC router - Original design BalloonEngineer CNC Routing 22 09-06-2019 12:01 AM
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
