Using router to shape plexiglass - Router Forums
 14Likes
  • 6 Post By pinehunter
  • 1 Post By Gene Howe
  • 1 Post By richjh
  • 2 Post By pinehunter
  • 2 Post By harrysin
post #1 of 8 (permalink) Old 06-07-2017, 03:34 AM Thread Starter
First Name: dave
Send a message via AIM to pinehunter
Default Using router to shape plexiglass
A replacement scratchplate was required for a mandolin using black plexiglass. Two templates were made, one for the outline shape and another for a guide bush to make pickup opening. The plastic was sawn freehand and made oversize using a washer and pencil. Two side tape was used to mount it on MDF shape. A 1/2" bearing guided standard cutter was used to cut plastic. A climbing cut was used cutting at 20,000 rpm. The pickup slot was made using the template stuck down with tape. A 16mm guide bush was used with a 8mm 2 flute straight cutter. Again a climbing cut was used.
pinehunter is offline
post #2 of 8 (permalink) Old 06-07-2017, 06:31 AM
Gene Howe's Avatar
First Name: Gene
Glad it was successful for you. Any melting noted? Suppose the climb cutting helped.
Nice job and, thanks for posting.
DesertRatTom likes this.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 8 (permalink) Old 06-07-2017, 07:20 AM
hawkeye10's Avatar
First Name: Don
Is climb cutting the way to cut cut plexiglas? I have not cut that before.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 8 (permalink) Old 06-07-2017, 07:24 AM
richjh's Avatar
First Name: Rich
I have used my router to round over edges and corners of 1/4" acrylic for making wet/dry filters for marine aquaria with no melting of the acrylic as long as you keep the router moving along the edge and don't let it sit in one place and create friction. This is messy and creates a lot of small plastic shavings that due to static charge stick to just about everything.
I used my jointer to create perfectly flat edges for gluing up the pieces. This will dull your blades and bits faster than wood. With the jointer, I moved the fence to use the blade edge more evenly. I used my table saw with a laminate blade to cut the sheet stock to size.
RainMan 2.0 likes this.
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #5 of 8 (permalink) Old 06-07-2017, 08:33 AM Thread Starter
First Name: dave
Whilst I cannot comment on every type of plastic suitable for routing Rich is spot on with his experiences. Gene there should be no melt back onto the cutter as long as there is constant movement between the plastic and the router bit. Don's point about climbing cutting is important. With a climbing cutter it gently pushes away from the cut substrate and allows greater control and less chance of a cutter snatch.
Gene Howe and jj777746 like this.
post #6 of 8 (permalink) Old 06-07-2017, 10:04 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
A replacement scratchplate was required for a mandolin using black plexiglass. Two templates were made, one for the outline shape and another for a guide bush to make pickup opening. The plastic was sawn freehand and made oversize using a washer and pencil. Two side tape was used to mount it on MDF shape. A 1/2" bearing guided standard cutter was used to cut plastic. A climbing cut was used cutting at 20,000 rpm. The pickup slot was made using the template stuck down with tape. A 16mm guide bush was used with a 8mm 2 flute straight cutter. Again a climbing cut was used.[/QUOTE]Nice work Dave. Regarding the rectangular cutout in the template, a very accurate way to achieve the cutout is to glue four pieces of MDF together as shown.
chessnut2 and ksidwy like this.
Harry
harrysin is offline
post #7 of 8 (permalink) Old 06-07-2017, 06:44 PM
Honored Member
First Name: pat
would not climb cut, no matter what cutter.
All samples: Anti-climb cut.
Quillman is offline
post #8 of 8 (permalink) Old 06-18-2017, 04:07 AM Thread Starter
First Name: dave
Parts have come from China at last.
tomp913 and Rogerdodge like this.
First mount your router.... SimonHartropp Table-mounted Routing 6 09-08-2015 01:39 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
