Dual Mitre track/T track - Router Forums
 6Likes
post #1 of 14 (permalink) Old 06-07-2017, 10:46 AM Thread Starter
Default Dual Mitre track/T track
Good morning,
I am preparing to install a Bench Dog Dual T Track/Mitre Track in a home built router table. Most of the commercial tables show the T track closer to the bit. While I don't suppose this is critical, why should the T Track be closer?
It seems to me that the mitre track must be spaced out far enough to prevent the mitre gauge getting into the largest bit usable, but the T track space in closer would hold a feather board better?
Am I missing the obvious? Thanks for suggestions.
Quaker Banjo Man is offline
post #2 of 14 (permalink) Old 06-07-2017, 11:26 AM
kp91's Avatar
First Name: Doug
QB,
Quick answer- wherever it works best for you.
I personally don't use miter track on the router table. If I did, it would be for mounting feather boards or other fixtures. If you get too close to the bit, then you might limit what feather boards you can use.
Since the bit is round, I use a miter gage that guides off of the router template guide. Look up "oak park miter gage" and you might find a picture.
For cope cuts and other end cuts I use a quick made sled that is guided off of the fence.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 14 (permalink) Old 06-07-2017, 12:24 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
If youre going to use clamps at each side of the bit for stop guides, you want the clamps as close as poss to the fence to stop lateral movement.
If youre going to use a mitre fence, you want the fence a goodly distance away from thbit to accommodate your work piece.
it would be extremely rare to use both tracks at the same time.
sunnybob is offline
post #4 of 14 (permalink) Old 06-07-2017, 06:21 PM
JOAT's Avatar
First Name: Theo
Never saw the need for a T track on a router table myself.
Gene Howe likes this.
JOAT is online now
post #5 of 14 (permalink) Old 06-07-2017, 07:10 PM
Gene Howe's Avatar
First Name: Gene
Ditto.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #6 of 14 (permalink) Old 06-07-2017, 09:14 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #7 of 14 (permalink) Old 06-07-2017, 10:51 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
If you are going to cut a recess or inside slot with a router table. you use stop blocks at either end of the work piece to determine where the cut is going to be.
For example, your coin tray can be cut on the router table.
Thats why you use T tracks.
This box was cut out of a solid block, just by using stop blocks on three sides and the fence as the back stop, and slowly winding the cutter up into the wood. The lid recess also.
JFPNCM, Gaffboat, TenGees and 1 others like this.
sunnybob is offline
post #8 of 14 (permalink) Old 06-07-2017, 11:40 PM
Terry Q's Avatar
I use a t-track for my kreg beaded face frame jig. Suppose to be 6 -1/2 inches from center of bit.
Sent from my iPad using Tapatalk
Terry Q is offline
post #9 of 14 (permalink) Old 06-08-2017, 08:51 AM
hawkeye10's Avatar
First Name: Don
On occasion when I need a third hand I have used mine for a feather board. Like when routing long narrow pieces.
TenGees likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 14 (permalink) Old 06-09-2017, 05:18 AM
I use the T track on occasion for mounting a featherboard. You might theoretically use it for a coping sled to cut rail ends for doors, although I just use a block of MDF to hold the rail square to the fence. And yes, welcome to the sawdust party.
Anyone use a Festool track saw ? RainMan 2.0 Tools and Woodworking 39 07-03-2015 03:07 AM
Router miter slot vs track jetjocky New Member Introductions 10 01-24-2015 08:14 PM
Where to position mitre track? Eazygeezer Table-mounted Routing 4 01-17-2014 05:38 PM
A "closed-in" mitre track? matt1710 Table-mounted Routing 8 05-22-2011 06:27 AM
Mitre slot : straight or T-slot? matt1710 Table-mounted Routing 5 05-10-2011 09:55 PM
