Oak-Park style table questions - Pt. 2 - features? - Router Forums
 10Likes
post #1 of 16 (permalink) Old 07-16-2017, 09:44 PM Thread Starter
username1's Avatar
First Name: Art
Default Oak-Park style table questions - Pt. 2 - features?
Probably should have posted pt. 1 in this forum but anyway,,
I am in need of a Router table, and I have decided basically what I want to build. Something very simple, inspired by the Oak-Park style table. But long enough to also work as a bench or assembly table.
It will live under a roof, but exposed to open air.
I have settled on a 2' x 4' workbench type table, with the Router mount near one end. Top will overhang around 2" on 3 sides (for clamping), and one end with no overhang and a Moxon type vise. Probably a 3/4" plywood + 1/2" birch plywood for a 1-1/4" top. Might cover with Laminate, not sure.
No vacuum hookups, nothing fancy in the way of Fences (just clamp-on).
I may decide to put bench-dog holes but not sure - A strip clamped across the width of the table may work just as well as bench dogs, and no need for holes..?
My main question is, what are the simple (DIY) features you built into your table and why do you like them? Or what did you find you did NOT like about your work bench?
"You kids get offa my lawn!"
username1 is offline
post #2 of 16 (permalink) Old 07-16-2017, 10:31 PM
how about this???
post #3 of 16 (permalink) Old 07-17-2017, 01:33 AM
JOAT's Avatar
First Name: Theo
The fact that I made a spiderweb of 2X4 chunks to support the 1/2" plywood top, and made my own router plates. What's not to like?
There IS no dislike, it does just what I want it to.
JOAT is offline
post #4 of 16 (permalink) Old 07-17-2017, 01:59 AM
I'm clamping the fence on the current table just like you. The last one had t track clamping. I haven't found one superior to the other. I do like my fence with moveable faces so that I can close up on a small diameter bit. Both the last two have had that and any future ones will also have that feature. They also had the center section boxed in for dust collection, also a keeper. The last two or 3 tables have had the plate offset to one side so that I can work on one side with narrow pieces and the other side for wide pieces. I'll keep that feature too. All my plates just sit in the table held by gravity. That way I can lift it out to change bits and make the initial height adjustment and it's much easier being able to do that. A laminate cover will last longer and is more slippery but it's not an absolute necessity.
jj777746 likes this.
post #5 of 16 (permalink) Old 07-17-2017, 04:25 AM
kp91's Avatar
First Name: Doug
Laminate the top. The reduced friction will be worth it
197761 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #6 of 16 (permalink) Old 07-17-2017, 07:30 AM
I agree with Charles. Clamping the fence works fine. Having movable sides is imperative to adjust for bit sizes. dust collection is also a must have and it is too easy not to incorporate it into your table. If you stick with a wooden top I suggest you wax it to make things slide easier. That would have to be done periodically and be sure to use a wax with no silicon...Johnson's wax is perfect. I would suggest you go ahead and laminate it. That is a one time deal, doesn't cost much and provides a better work surface.
kp91 likes this.
billyjim is offline
post #7 of 16 (permalink) Old 07-17-2017, 08:21 AM
Bushwhacker's Avatar
First Name: David
All the above ideas are very good, it depends on what you want. My table I built is just like the one that Stick showed you, minus the router. I also added the shelf under the table.
You will be surprised how fast you can fill that shelf up. Plus it adds to the sturdiness of the table.
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #8 of 16 (permalink) Old 07-17-2017, 09:44 AM Thread Starter
username1's Avatar
First Name: Art
Thanks for the opinions.
Is 2" of overhang sufficient for clamping or have you found the need for more?
Since this is a budget project, would Hardboard be a decent top? I could put it together in a way that I could replace the layer of Hardboard if it got too beat up.
post #9 of 16 (permalink) Old 07-17-2017, 02:10 PM
1 1/2 to 2" is enough. Just make sure the underside is flat with no lips or dips. The clamps may not stay tight if there are.
post #10 of 16 (permalink) Old 07-17-2017, 02:33 PM
TWheels's Avatar
There was a thread in 2006 that dealt with many of these issues. I call your attention especially to posts 13 and 14 that deal with the Oak Park (Router Workshop) table dust collection.
http://www.routerforums.com/table-mo...r-table-2.html
197761 likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
Sold: Oak Park Router Table granjeff Woodworking Classifieds 5 07-26-2019 01:22 PM
For Sale: New oak park router table retired doug Woodworking Classifieds 4 11-16-2015 03:11 PM
Oak Park Table - no more - no longer RegisG Table-mounted Routing 4 10-06-2011 09:29 PM
Problems with Oak Park Router Table Top dcgordon01 Table-mounted Routing 4 09-26-2011 07:49 AM
Oak Park REouter Table Top Opening cbsjoez1935 Table-mounted Routing 12 04-05-2007 01:18 PM
