PC. 7518 problems - Router Forums
post #1 of 21 (permalink) Old 08-02-2017, 03:44 PM Thread Starter
Default PC. 7518 problems
I have a PC7518 mounted in a table. The motor will come up to speed but when you put a load on it the speed goes down drastically. I have checked the brushes and they are in execellent shape. Any advise on other things to check?
Also, within the last 6 months or so I received an email advertising a 3 plus HP router with an external speed control(speed control mounted outside router table). I have searched the net but can not find. Is anyone aware of who sells this and any reviews of it?
Tom
Tom in NC is offline
post #2 of 21 (permalink) Old 08-02-2017, 04:40 PM
DonkeyHody's Avatar
First Name: Andy
Does it make a difference what speed you are using??
I believe the electronic speed control module on your router has died. My research shows that this is a common issue with the 7518. My 7518 works fine on the highest speed, but bogs down on low speed. The speed control module is available online at ereplacementparts.com, but it costs $125. Instead of repairing mine, I invested in a Triton router. Now I use the PC 7518 for bits that can spin at top speed, and the big Triton for Panel-Raising bits. You can never have too many routers.
The speed control module on the 7518 was first-generation technology and was never as good at speed control as the newer models such as the Triton.
DonkeyHody is offline
post #3 of 21 (permalink) Old 08-02-2017, 05:04 PM
brushes, speed control, bearings, armature/feild in that order,,
post #4 of 21 (permalink) Old 08-02-2017, 05:06 PM
Router Forums - Search Results
post #5 of 21 (permalink) Old 08-02-2017, 05:08 PM
change the capacitors in your controller..
post #6 of 21 (permalink) Old 08-02-2017, 05:13 PM Thread Starter
Thanks Andy. I was on the slowest speed using a raised panel bit. I will try the high with a small bit. Do you know if the router you recommended will fit a lift for the PC7518 without an adapter? I have the bench dog lift.
post #7 of 21 (permalink) Old 08-02-2017, 09:23 PM
DonkeyHody's Avatar
First Name: Andy
I don't know about lifts, I've never had one. But I'll bet someone will be along in a while to answer your question.
post #8 of 21 (permalink) Old 08-02-2017, 10:14 PM
Tom, the Triton has its own built in lift. A lower cost alternative that will fit your lift is the Portamate router motor. This router will even work with your 7518 collets.
Name:	Portamate Router 1.JPG
Name:	Portamate Router 2.JPG
post #9 of 21 (permalink) Old 08-05-2017, 10:01 AM Thread Starter
I checked my router on high speed today with a 1/2" round over bit. It worked fine. I'm wondering if I can purchase an external speed control and have my router set on it's high speed and slow it down with an external speed control. Just don't know enough about this type motor.
Tom
post #10 of 21 (permalink) Old 08-05-2017, 10:07 AM
Tom
no...
you will have to remove/bypass the router's speed control for the external speed control to work...
someplace on this forum is the schematic to do that...
Porter Cable 5182 Versus 7518 Richard Carter General Routing 5 03-11-2019 11:47 AM
Problems, Problems, Problems..... Frankj3 Sign Making 9 07-04-2016 09:21 PM
Problems, problems, problems nikki1492 General Routing 7 07-21-2009 08:50 AM
Porter router 7518 problems (URGENT!!!!!!) marc.brunet.gagne General Routing 2 04-30-2008 08:52 PM
