Picture frame miters - Router Forums
 12Likes
  • 1 Post By harrysin
  • 2 Post By jg2259
  • 6 Post By vindaloo
  • 2 Post By chessnut2
  • 1 Post By vindaloo
post #1 of 10 (permalink) Old 08-05-2017, 06:07 AM Thread Starter
Default Picture frame miters
Hi all, I am trying to acquire some info on making a spline in a frame to strengthen the miters. Actually it's not a picture frame, but a frame for the top of a box (with panel).
I am using a 5/32" slot cutter in my router table, and plan on using #10 biscuits.
I don't want to use splines, as I don't want the splines to show through the outside of the miters.
I am trying to figure out a SAFE and accurate way of slotting the miters for the biscuits, so that the biscuit is in the center of the miter both in thickness and length.
I am posting a pic of what I am trying to do.
Thanks for any guidance or direction.
Jim
Sent from my iPhone using Tapatalk
Jim Gallo is offline
post #2 of 10 (permalink) Old 08-05-2017, 09:28 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
It's so much quicker and easier using a biscuit jointer which are available at quite modest prices. Using a slot cutter in the router table working with narrow pieces is very difficult to keep from rocking, however, if that is the only way then a block cut to 45 similar to that shown on the saw table in photo #13 would be a BIG help.
File Type: pdf Jacaranda trinket box made from a branch cut from a friend.pdf (1,020.7 KB, 40 views)
gjackson52 likes this.
Harry
harrysin is offline
post #3 of 10 (permalink) Old 08-05-2017, 11:13 AM Thread Starter
Thanks Harry
post #4 of 10 (permalink) Old 08-05-2017, 11:13 AM
Bisquit cutter makes it easy. If I were going to use a slot cutter, I'd make a 45 degree jig to clamp against the table so I could slide the frame toward the cutter, using the edge of the fence opening as a stop.
On my frames, I usually assemble first, then put the frame into an L-shaped spline jig, and use a 1/8th inch, flat tooth blade to cut a slot for the spline. My splines are generally some sort of exotic wood that makes a nice contrast. I often use purplewood. I also do a lap miter from time to time, which gives you about the same glue surface as a biscuit but also provides for a rebate for the canvas stretcher.
Biscuits make a very clean, modern looking frame. That's a nice looking piece of work.
post #5 of 10 (permalink) Old 08-05-2017, 11:28 AM
hawkeye10's Avatar
First Name: Don
I don't know how good they are but Harbor Freight has a biscuit plate jointer for $65 plus you can get a 20% off coupon. Just remember this tool may not be very good. Maybe someone who has expedience with them will chime in.
https://www.harborfreight.com/4-in-b...ner-68987.html
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 10 (permalink) Old 08-05-2017, 01:48 PM
Using your set up on the router table, You might try a zero clearance insert in the fence so that the only thing showing is your cutter,not open gap.
Then set up an angle stop the width of your frame material on each side the same as your picture shows. Then slide the material slowly into the cutter holding it down firmly to the table. Turn it over to do the other end.
You might make the stops as thick as your material and put a piece on top to hold the frame material down to the table when pushing it into the cutter.
Herb Stoops is offline
post #7 of 10 (permalink) Old 08-05-2017, 04:25 PM
Thank you everyone. I don't think I will invest in a biscuit cutter, as most of my joining is done with the Dowelmax. However I did use your recommendations and the slots came out perfect using the angled guides.
Thanks again!!!
Sent from my iPad using Tapatalk
DesertRatTom and TenGees like this.
jg2259 is offline
post #8 of 10 (permalink) Old 08-05-2017, 09:59 PM
vindaloo's Avatar
First Name: Angie
Make a simple jig
The outside two pieces are fixed and guide the larger squarish piece towards the fence. Clamp your project stock between the to 45 degree pieces, and slide towards the fence and cutter. Definately repeatable for height. Can be made out of scrap laying around the shop.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #9 of 10 (permalink) Old 08-06-2017, 08:08 AM
chessnut2's Avatar
Nice jig, Angie.
DesertRatTom and Herb Stoops like this.
chessnut2 is offline
post #10 of 10 (permalink) Old 08-06-2017, 03:10 PM
vindaloo's Avatar
First Name: Angie
Originally Posted by chessnut2 View Post
Nice jig, Angie.
I saw it on a video. The only difference was that guy was doing it straight on. Not sure what the video was about now, memory is fading...........
Herb Stoops likes this.
vindaloo is offline
Picture frame kywoodchopper Project Plans and How To 4 11-06-2016 03:43 PM
Picture frame kywoodchopper Project Plans and How To 8 11-06-2016 09:54 AM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
