Freud Diablo Raised panel set. - Router Forums
post #1 of 15 (permalink) Old 01-22-2009, 09:58 AM Thread Starter
derek willis's Avatar
First Name: Derek
Default Freud Diablo Raised panel set.
In two weeks time I will be visiting the International Woodworking exhibition at Alexander Palace, in London, for about the 17th. year running.
Last year on the Freud stand they had a raised panel and stile set named Diablo on offer for 35:00 I looked at it at least six times, not beleiving it could be any good, anyhow, in the end I bought it.
Later last year I got a contract to make a full set of doors for a largish kitchen, 20 odd doors and 7 drawer fronts, here is the set on my very old home built table and some of the doors being finished, I used Rusting Plastic Coating.
http://farm4.static.flickr.com/3335/...0b7891e1fc.jpg
derek willis is offline
post #2 of 15 (permalink) Old 01-22-2009, 10:11 AM
xplorx4's Avatar
First Name: Jerry
You know Derek I am using some of their saw blades one 12" and one 10" and I like them very much. OK I am no better at the $ (don't even have the other symbol) conversions than I was back when I visited your great country courtesy of the US Navy, than I am now. Ball park, what would it set me back? BTW would love to see a pic of the doors you have made.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 15 (permalink) Old 01-22-2009, 10:17 AM
Yes we want to see the doors. You have big doors over there.
vikingcraftsman is offline
post #4 of 15 (permalink) Old 01-22-2009, 12:16 PM
Country: Brazil
First Name: Renato
Derek, I agree with you Freud bits really have good quality. They have also very good circular saw. I also like the Infinity bits and saws and specially the the knives they developed for DW735 Planner.
Does anybody have the opportunity to compare the Freud and Infinity bit quality?
Renato is offline
post #5 of 15 (permalink) Old 01-22-2009, 12:30 PM
HI derek
You may want to think long and hard about that set of bit's, Freud makes great bits, but that set is a real tricky to setup,,for the R & P parts..unless you like to sand all day long to get the parts down to be flat with each other.
You may want to look at a matched set of bits,will make your job a lot essayer ...
http://www.amazon.com/Freud-97-106-C...2648666&sr=1-1
post #6 of 15 (permalink) Old 01-22-2009, 01:08 PM
Charles M's Avatar
HI derek
Bob,
Why do you say that? Once the bit height is set, what would cause the surfaces to not be coplanar?
Charles M is offline
post #7 of 15 (permalink) Old 01-22-2009, 01:27 PM
HI Charles
I have use that type of bit,,once you cut the cope, you must reset the bit to do the bead
That's when the error comes into place..
If you are off just little bit you are in for a lot work, or if you like making firewood... it's a great bit for that job...
The easy way is to use a matched set of bits, and not move the router up or down when you replace the bit......
Originally Posted by Charles M View Post
Bob,
post #8 of 15 (permalink) Old 01-22-2009, 01:56 PM
dovetail_65's Avatar
First Name: Dovetail
I won't use anything but a matched set. And be careful just becasue a set may have two bits they may not be a matched set.
Bob is 100% correct once you have to change the bit height you are scre***.
Put a rubber grommet in the bottom of the router and drop in bit one and cut, then drop in bit two and cut. Perfect every time.
No touching the lift, no muss no fuss.
dovetail_65 is offline
post #9 of 15 (permalink) Old 01-23-2009, 04:08 AM Thread Starter
First Name: Derek
Charles,
I have had no trouble with the setting up, and the finish is excellent, at my first setup I kept set up pieces so that each time I would have the same,
As for picutures, I am new here and have not got to grips with it, you will see a url that should have been a picture.
My price of 35 would be about $42, I think, at todays rate.
Derek.
post #10 of 15 (permalink) Old 01-23-2009, 04:18 AM Thread Starter
First Name: Derek
Here goes another try to put in the pictures.
<a href="http://www.flickr.com/photos/[email protected]/3218213890/" title="Picture 001 by derekwillis16 Enigma, on Flickr"><img src="http://farm4.static.flickr.com/3335/3218213890_0b7891e1fc.jpg" width="500" height="375" alt="Picture 001" /></a>
<a href="http://www.flickr.com/photos/[email protected]/3218216806/" title="Picture 002 by derekwillis16 Enigma, on Flickr"><img src="http://farm4.static.flickr.com/3454/3218216806_9e87364645.jpg" width="500" height="375" alt="Picture 002" /></a>
<a href="http://www.flickr.com/photos/[email protected]/3217368011/" title="Picture 001 by derekwillis16 Enigma, on Flickr"><img src="http://farm4.static.flickr.com/3126/3217368011_de829231b9.jpg" width="500" height="375" alt="Picture 001" /></a>
Vertical Raised Panel Question rprice54 General Routing 23 03-14-2014 11:29 PM
Freud Diablo Raised panel set. derek willis Table-mounted Routing 0 01-22-2009 09:55 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
