Does size matter? - Router Forums
post #1 of 7 (permalink) Old 01-23-2009, 07:20 PM Thread Starter
scotirish10's Avatar
First Name: Ronald
Default Does size matter?
I am making puzzles for my youngest grandchildren. I need more than one of each so I made a pattern for all the various ones. I wanted to make them out of pine (3/4"). I used a 1/8" pattern bit to make them. The problem is that on the up swing, against the grain, as I reach the top to pass over and go down on the grain it rips off a chuck of the wood. I thought of three possible solutions; 1) back cut on all of these areas, 2) use a larger dia. bit or 3) slower speed. What do you think?
scotirish 10
Work safe: Remember the only 'SAFE' power tool in the shop, is the one with the plug pulled out of the socket!
If you have an open mind is there a chance your brain might fall out?
scotirish10 is offline
post #2 of 7 (permalink) Old 01-23-2009, 07:47 PM
HI scotirish10
The router is a great tool but I would recommend the scroll saw for that job, I make them all the time for my grandchildren, just stick on the pattern and just cut them out easy, if you use the right saw blade no sanding needed..
When I'm bored on Sat. and when the kids are about, I cut out 2 or 3 out in about 10 miins..and say OK kids fix them and in about a hour or two them have them done with.. they are 4 and 5 years old..I can't say how many I have done but it's been going on that way for about a year or so.. LOL LOL, most end up in a plastic bag and they take them home
post #3 of 7 (permalink) Old 01-24-2009, 08:51 AM Thread Starter
First Name: Ronald
Thanks BJ. I was trying to save time. As I am retired, come to think of it all I have is time, I will follow your suggestion.
scotirish 10
post #4 of 7 (permalink) Old 01-24-2009, 09:50 AM
You're Welcome scotirish
I do like to make them and I'm sure you will to,,,I turn on the scroll saw all the time just to play with it,,I'm always trying to do it smaller just for kicks Here's a snapshot of some of the ones I put to one side.. plus you will see a trick puzzle below that's fun for the kids to do.. it looks easy but it can take some time to get all the parts back in place..
http://homepage.ntlworld.com/bruce.v...d%20puzzle.pdf
http://homepage.ntlworld.com/bruce.v...ck%20Plans.pdf
http://homepage.ntlworld.com/bruce.v...0page%202.html
post #5 of 7 (permalink) Old 01-25-2009, 08:07 AM Thread Starter
First Name: Ronald
Thanks again BobJ. I am going to make the puzzle tomorrow.
scotirish 10
post #6 of 7 (permalink) Old 01-25-2009, 08:44 AM
You're Welcome scotirish10
I should note the scroll saw is a great way to make signs
Many like to plow out the back ground when making a sign but it's easy with the scroll saw, just stick 2 boards together cut out what you want then split the boards and you make it proud or recess very easy and it's very clean all in one shot... plus it can be any font you want it to be..
post #7 of 7 (permalink) Old 01-26-2009, 07:56 AM Thread Starter
First Name: Ronald
I have done that. I planed down one board to be about 1/8" thinner. double taped them together and cut the letters out. Gives me two signs, one with the letters proud and the other with letters inset.
scotirish 10
guide bushing size chart mharwell01 Guide Bushings and Templates 21 08-18-2017 10:37 AM
How to make different size lables S Bolton Lobby 17 11-29-2008 12:41 AM
Router bit and Router size for CNC? macg CNC Routing 17 04-07-2007 12:13 AM
Router Bit Size Marking ? joeohlandt Router Bits - Types and Usage 5 04-06-2007 01:09 AM
What size is it? Thread size... mountainguy Tools and Woodworking 1 08-20-2006 02:02 PM
