Bosch RA 1250 dimensions - Router Forums
post #1 of 4 (permalink) Old 08-26-2017, 01:50 PM Thread Starter
First Name: Andy
Question Bosch RA 1250 dimensions
I'd like to use the Bosch RA 1250 table insert in my own table. I know the thickness but not the dimensions.
Can someone provide me with the length and width of the insert. I'm hoping it is 9" x 12".
If not any suggestions for a 9x12 insert plate? Peachtree is out of stock on there aluminum plate. MLCS has a 9x12 but it is a bit more expensive.
Thanks in advance,
Andy
njtrout is offline
post #2 of 4 (permalink) Old 08-26-2017, 02:01 PM
Yup; 9" x 12"
https://www.boschtools.com/us/en/bos...a1250-27263-p/
DaninVan is online now
post #3 of 4 (permalink) Old 08-26-2017, 04:04 PM
why not make your own..
Stick486 is offline
post #4 of 4 (permalink) Old 08-27-2017, 12:57 PM Thread Starter
First Name: Andy
(whoops - The RA 1250 is phenolic plastic.) If i had the metal working skills I would. Rather have metal plate since i I have the MRC23 Bosch router which is rather heavy. Thanks for the suggestion though.
Andy
njtrout is offline
Bosch JS572EL and JS572EBL jig saws Mike Tool Reviews 6 07-04-2015 06:05 PM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
Shaft wrench for Bosch 1617EVS nn4jw Table-mounted Routing 9 02-17-2014 09:06 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 09:44 AM
