Shaker Door Help - Router Forums
post #1 of 3 (permalink) Old 01-25-2009, 08:07 PM Thread Starter
Default Shaker Door Help
Need help please. I'm using a T/G set (Katana) and made my first test door
all was good except I'm getting paper thin material left when cutting the rails
I'm using a sled also any advise, other then that the door came out a little
out of square but that was my fault.
williams94 is offline
post #2 of 3 (permalink) Old 01-25-2009, 08:58 PM
HI williams94
This can come about when the bit needs to be shimmed or the stock is over the max size for the bit set, you should have some shim washers with the bit set..put one in the cutter with the bearing in the center..if you didn't get any extra shims you can use one out of one of your other bits...it will look like a very thin copper flat washer, it only takes one the norm..
then run some test parts and see how it comes out...
post #3 of 3 (permalink) Old 01-27-2009, 04:10 PM
xplorx4's Avatar
First Name: Jerry
hi williams3, welcome to the forum. Take a moment and give us some news about yourself. This will move you back to the top so you might get some more attention. Although I gotta tell ya that it don't get much better than BobJ.
Lamentations 3:22-23
xplorx4 is offline
Shaker door Material williams94 Table-mounted Routing 2 03-11-2009 10:39 AM
shaker doors hillman New Member Introductions 6 01-28-2009 08:51 AM
Shaker Hall Table bobj3 Project Plans and How To 3 06-27-2007 08:22 PM
Shaker style doors lablover Router Bits - Types and Usage 7 05-21-2007 07:02 PM
Finishing shaker pegs Qstick The Finishing Touch 7 02-27-2007 03:27 PM
