Using Collet Adapters - Advice please - Router Forums
 4Likes
  • 2 Post By djcook
  • 1 Post By dovetail_65
  • 1 Post By Cherryville Chuck
post #1 of 10 (permalink) Old 09-01-2017, 05:39 PM Thread Starter
Default Using Collet Adapters - Advice please
Hey Friends,
I'm using a Triton 3-1/4 HP TRA001 router mounted in a router table. Using the Leigh 1/2" to 8mm collet reducer to use the 8mm Leigh router bits that work with the Leigh RTJ400 dovetail jig.
Using this setup today, it apparently slipped slightly down during use and cut a lower height than intended. No harm done, as I caught it time, but now I'm wondering if there's some trick to using collet reducers? I thought I had it tightened down with plenty of force, but I don't want to over-tighten either.
Do any of you have some tips in using using collet reducers? Is there a trick in aligning the adapter slot openings to the main collet openings? Also, I presume the adapter should seat all the way down onto the main collet (there's a ridge/collar on the reducer top end) or should it sit slightly above the main collet?
Also, if any of you have a good source for the standard Triton 8mm collet that would be appreciated.
Thanks for any help you can provide.
Dave
djcook is offline
post #2 of 10 (permalink) Old 09-01-2017, 05:50 PM
Terry Q's Avatar
I've had the same problem. I think the combination of bit/reducer/collet getting too hot, expanding, and coming loose. I dealt with it by letting it cool down every few minutes.
Terry Q is offline
post #3 of 10 (permalink) Old 09-01-2017, 05:52 PM Thread Starter
Good advice. I also just received this from Leigh:
"The collet reducer has several shallow machined slots and one slot that goes completely through. The only “trick” is to line up the through slot on the collet reducer with a similar slot on the router collet. Most collets have a series of slots to allow compression. The through slot on the collet reducer should be lined up with the largest slot."
I'll try this setup next time I get back out to my project.
Thanks,
Dave
harrysin and Semipro like this.
djcook is offline
post #4 of 10 (permalink) Old 09-01-2017, 06:11 PM
dovetail_65's Avatar
First Name: Dovetail
Why aren't you just using the 8MM collet? I thought they made one for that router. They sell them in the UK so you may need to go to ebay.
Is this is?
http://www.yandles.co.uk/triton-8mm-...-tra001/p18108
harrysin likes this.
dovetail_65 is offline
post #5 of 10 (permalink) Old 09-01-2017, 06:29 PM Thread Starter
I've been trying to locate the 8mm collet. My USA-purchased product came with the 1/4" and 1/2" collets only; with the Leigh kit providing the 8mm adapter. Seems a challenge to find the 8mm in the USA. Will try eBay.
Thanks.
djcook is offline
post #6 of 10 (permalink) Old 09-01-2017, 08:46 PM
This place will send the 8 mm collet to USA, just message them to ask when the are back in stock.
Triton 516353 Router Collet 8mm TRC008 Collets Routers Plunge routing sleeve | eBay
post #7 of 10 (permalink) Old 09-01-2017, 09:23 PM Thread Starter
Thanks much. Looks like the best source so far. Much appreciated.
djcook is offline
post #8 of 10 (permalink) Old 09-02-2017, 12:03 AM
I know that PhilP from the UK used to say that he had poor luck using bushings and yet others, including myself, have had none. Phil is a contractor and I'm a long time DIYer. The difference would be that he might run the setup for hours and I would likely be minutes. As suggested the problem might be heat. If you run it more than a few minutes then maybe try tightening it up again once it starts getting hot. This is always why I thought Phil's experience was different than mine.
Job and Knock likes this.
post #9 of 10 (permalink) Old 09-02-2017, 08:49 AM
hawkeye10's Avatar
First Name: Don
I haven't heard of anyone having this problem with a 1/4" collect reducer in a Muscle Chuck. I just got a MC and haven't used the 1/4" reducer yet.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 10 (permalink) Old 09-04-2017, 09:58 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
A Musclechuck and their 8mm reducer are, in my opinion the way to go. The Musclechuck has a grip several times stronger than a standard collet chuck and only requires a 1/2 turn of a 4mm Allen key to lock solid.
Harry
harrysin is offline
bits and collet issues captflx Router Bits - Types and Usage 11 04-28-2017 08:21 PM
Searching for a collet? Mike General Routing 12 06-21-2013 07:30 AM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
How far to insert collet adapters? TWheels General Routing 3 05-28-2008 04:18 PM
Collet Adapters holdstock New Member Introductions 2 01-15-2007 11:55 AM
