Muscle Chuck problems Still!!! - Router Forums
 31Likes
post #1 of 24 (permalink) Old 09-10-2017, 10:40 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Muscle Chuck problems Still!!!
I have been trying to make a dado and the Muscle Chuck won't let the bit go low enough without the router motor falling. The router bit has a 1/4" shank and a 1" cutting length. My router is a PC 895 and I am using it in a router table.
I have wasted money on this piece of you know what.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 24 (permalink) Old 09-10-2017, 10:47 AM
Gaffboat's Avatar
First Name: Oliver
I use a muscle chuck on my Dewalt 618 and it's extra length and diameter does occasionally create problems like you are encountering. When all else fails, you can always replace the muscle chuck temporarily with your original collet for the operation you are trying to do. I find the muscle chuck works very well for the majority of my router table and hand held operations.
Mike, JFPNCM and RainMan 2.0 like this.
Gaffboat is offline
post #3 of 24 (permalink) Old 09-10-2017, 11:04 AM
use a shorter cut length on the bit...
Mike and tomp913 like this.
post #4 of 24 (permalink) Old 09-11-2017, 09:48 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Whatever your problem is Don., it's most unlikely to be the MUSCLECHUCK which is a super precision piece of engineering.
Mike, RainMan 2.0 and jj777746 like this.
Harry
harrysin is offline
post #5 of 24 (permalink) Old 09-11-2017, 09:01 PM
dovetail_65's Avatar
First Name: Dovetail
This has nothing to do with the Muscle Chuck as most people buy the thing not just for the ease of bit change but for extended reach! Everyone knows the Muscle Chuck adds a bit of a reach and in most cases is what users want. I swear somewhere it states it add 1/2" or additional reach or interference on shallow operations. Possibly I read that somewhere else, I think this is a generally known drawback for certain operations though. Possibly you didn't know this and found out the hard way. This doesn't make the Muscle chuck crap by any means.
Just use the regular collet set up for this one operation.
Okay I just pulled out my Muscle Chuck and it states right in the instructions I have printed up "adds 1/2" to reach". So it's nothing to do with the Muscle chuck at all. It's doing what it is supposed to do, it's the operation that is wrong for the tool(accessory in this case) chosen. This is a case of leaving a poor remark for something doing basically what it's designed to do and counting that against it. It's intend use is exactly what's not needed for the particular described operation.
dovetail_65 is offline
post #6 of 24 (permalink) Old 09-11-2017, 09:56 PM Thread Starter
hawkeye10's Avatar
First Name: Don
I went back and read my original post and I did bad mouth the MC but I was wrong. It is a quality piece of work. When I bought the MC they called and ask if I was going to use it in a router table and I said yes. They said I needed the extended version and I said okay. Of coarse it didn't work and they swapped it out at no cost to me. I thought I had everything solved but when I but a bit in there with a cutting length of 1" and the I couldn't make my cut I was mad and disappointed. The reason and only reason I bought the MC was because I was having trouble changing bits in the router table. My offset wrench was slipping off a lot and I was afraid I was going to break the carbide on one of my bits. I got a new router table with a lift and I hope I will be able to use the MC with it.
post #7 of 24 (permalink) Old 09-11-2017, 11:32 PM
You can also clamp a 3/4" thick of plywood on the table with a hole for the bit to raise up the stock you are cutting.
just a suggestion,
RainMan 2.0, hawkeye10 and furboo like this.
Herb Stoops is online now
post #8 of 24 (permalink) Old 09-12-2017, 08:57 AM
CharleyL's Avatar
First Name: Charley
just a suggestion,
While I don't have a Muscle Chuck, I do have a couple of extra long bits.
I have a plywood top that I add to my router table when I can't drop the bit low enough for what I'm trying to do with those bits. One of these bits is a 1/2" shank flush trim bit and retracting the router to it's full extent leaves almost 1 1/2" of bit still sticking out of the router.
Charley
Gaffboat and Herb Stoops like this.
Central North Carolina
CharleyL is offline
post #9 of 24 (permalink) Old 09-12-2017, 07:37 PM
You were frustrated I have been there, we all have believe me. I hope the new router table works well for you.
Do you have one of those bent wrench(some call it an offset wrench) for the router collet? I found mine helped me get the bit out much faster and simpler when I did a lot of router table work without some kind of extended reach collet. It allowed me to get at the collet when it was below the table surface. This might help for the times you can't use that muscle chuck. They make the bent wrench for some of the most common routers. I must have at least 3 for different routers.
I never know when stuff is obvious or it may be helpful. For most guys that know about them ignore me, but for the few newbs that aren't aware these bent wrench may be helpful, I used mine quite a bit:
Name:	bent wrench.JPG
post #10 of 24 (permalink) Old 09-12-2017, 07:49 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Do you have one of those bent wrench(some call it an offset wrench) for the router collet? I find mine helped when I did a lot of router table work using a regular collet. It allowed me to get at the collet when it was below the table surface. They make the bent wrench for some of the most common routers.
Yes I do have an offset wrench and it's all buggered up. That is the wrench that keeps slipping off. I think it's made of that metal the Chinese dumps in the ocean and brings it back up when needed. Don't really know if that is true or not but I heard that is what they do.
tomp913 and Herb Stoops like this.
A Chuck add to Muscle Chuck question. hawkeye10 Table-mounted Routing 13 08-15-2017 08:59 AM
muscle chuck roofner Table-mounted Routing 30 09-13-2016 10:55 PM
Muscle Chuck Experience? ssevey17 General Routing 39 01-27-2015 09:03 AM
M12V and Muscle Chuck/Eliminator Chuck jlmacd General Routing 5 05-10-2012 06:23 PM
problems with chuck basser General Routing 1 05-25-2009 07:06 PM
