Safely Routing T-Moulding for flooring transition - Router Forums
 1Likes
post #1 of 14 (permalink) Old 09-11-2017, 12:16 PM Thread Starter
Default Safely Routing T-Moulding for flooring transition
Hi all. Hoping for some help. I have installed new flooring in my home and need some transition pieces from tile to hardwood. I need 4 in total. There is only about a 1/16 height difference between the two floors. I have a lot of flooring left over so I was hoping to use what I have. Floor is 2 1/2 inch X 3/4 inch hickory boards. While they are finished they are not stained so any cut edges are easily fixed with sanding and some satin poly. I am not a fan of cutting on end on the table saw so was hoping to use the router table. I tested one by first routing a round over edge profile so this did not have to be done later. Then I routed the first side a little at a time using a half inch straight bit. The first side is not an issue. The problem is supporting the piece while routing the second side and keeping it from tipping. I was able to finish the first one by resting the first side on a piece of 1/2 inch mdf while the other side was up against the fence. But it felt far from safe. Hoping someone has done this before and maybe give some tips or perhaps a jig they used to do it.
Thanks all.
bill0199 is offline
post #2 of 14 (permalink) Old 09-11-2017, 12:24 PM
take it to the table saw..
post #3 of 14 (permalink) Old 09-11-2017, 12:33 PM Thread Starter
... so your solution to my apprehension to doing it on the table saw is to take it to the table saw.
bill0199 is offline
post #4 of 14 (permalink) Old 09-11-2017, 12:50 PM
yup..
rip to width... leave the piece long..
do your RO...
double kerf from the back/bottom flat to a depth of your liking... also, the distance between the kerfs is the desire thickness of the T's web...
rotate the piece 90° so that the face/top is against the fence and complete the rabbet...
trim to fit...
post #5 of 14 (permalink) Old 09-11-2017, 12:55 PM
Note..
you should have an array of feather boards, push sticks and blocks to run an assist on this...
post #6 of 14 (permalink) Old 09-11-2017, 02:34 PM Thread Starter
Note..
The first rabbet doesn't faze me. The second does. So on the second rabbet I set up a featherboard up above blade, and tight to the initial rebate on the first side of the board?
bill0199 is offline
post #7 of 14 (permalink) Old 09-11-2017, 03:08 PM
Contributor of the Month
Which floor is higher, the tile or the hardwood? You're treating this as T molding? I've done this and usually cut a 15 degree chamfer on the edges of T molding. I use a 15 degree router bit and run the T
molding on edge on the router table. Then rabbet the bottom of the T molding so that the edges that sit on the floor and tile are no less than 1/4" thick. If there is an expansion gap between the hardwood and tile put a center support on the subfloor to support the center of the T molding.
JIMMIEM is offline
post #8 of 14 (permalink) Old 09-11-2017, 03:25 PM Thread Starter
The hardwood is higher. As I said by about 1/16". So T moulding is fine as I will rebate 1 side 1/16th deeper. There is a half inch gap between floors and I intend to support the moulding below. So one side will be 1/4 inch thick and the other 5/16.
bill0199 is offline
post #9 of 14 (permalink) Old 09-11-2017, 04:03 PM
If you leave the floor board full thickness you can first do the chamfers on the router table or table saw with the boards on edge then cut the rabbets with a table saw dado blade or on the router table. Either way a piece of scrap after the first rabbet is cut will prevent the board from tipping when you cut the second rabbet. Leave a 1/2" wide full thickness strip down the center of the board.
JIMMIEM is offline
post #10 of 14 (permalink) Old 09-11-2017, 04:58 PM
I would also use the table saw. And what else I would recommend you doing depends on what tools and experience you have which was why you were encouraged to fill out your profile when you became a member. If you can use a full thickness piece of the hardwood then the solution is easy. And safe. You implied that there is a gap between the tiled portion and the hardwood portion. I'm assuming that the gap is the same depth as the hardwood. What you'll do is to machine a lip on either side of a strip of that flooring. How thick depends to some extent on how wide the lip needs to be to cover the hardwood. If the lip is narrow then maybe 1/16" is enough. Wider and you'll need at least 1/4" thick. You'll set the saw fence so that with your piece on edge against the fence the saw cut will leave the thickness of the lip against the fence. The only time you'll see the blade is as it exits the cut. Flip it over to the other edge and set the fence for the thickness of the lip for the tiled side and do the same thing. Now all you have to do is set the board down flat and use the fence to get the width of the lips you need. Once again, the only time you'll see the blade is as it exits the cuts but as Stick pointed out you should be using push blocks or sticks to do this. This is an easy job and not particularly dangerous.
The transition strip won't be thick enough to touch the floor so you'll need to shim under it to support it or you risk breaking the lips off. You could take a scrap board and cut the correct thickness on the TS if you want. That might be easier and faster..
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Routing a flute blank safely dtaylor15 General Routing 9 05-20-2013 05:15 PM
I need some advice routing patterns safely. kitcheng33k Table-mounted Routing 2 10-19-2010 04:36 PM
Newbie looking for help on routing curved moulding. Dan_H Jigs and Fixtures 5 06-27-2009 07:10 AM
Pattern Routing With Hard Wood -- Safely!!! richnj General Routing 8 12-20-2008 09:32 PM
