obnoxious rockler dust port question - Router Forums
post #1 of 34 (permalink) Old 01-30-2009, 11:25 PM Thread Starter
First Name: pascal
Default obnoxious rockler dust port question
I just got my new Rockler router table up and running and would really like to get the shopvac hookup up to it. I got the accessory kit which includes a 2 1/2 inch dust port - cool, I have a 2 1/2 inch ridgid shop vac.
The hose just barely will not fit into the port - maybe 1/16th or less. Yes, I am taking the smaller end of the hose and trying to get it in there.
I have female-female and male-male coupler - nothing fits - anyone else have this problem?
thanks!
blurry is offline
post #2 of 34 (permalink) Old 01-30-2009, 11:47 PM
HI blurry
This just a temp fix ,but get your duck tape out..you can pickup one from Rockler...
If you have some hole saws you can make your own adapter
Just one more way, stop by HD/Lowers and pickup a pipe repair pipe kit, it's just some rubber hose and two hose clamps.
thanks!
post #3 of 34 (permalink) Old 01-31-2009, 12:24 AM
BJ, how often has this been asked about this before? It is such a common problem; this should go out as a router tip.
post #4 of 34 (permalink) Old 01-31-2009, 01:06 AM
xplorx4's Avatar
First Name: Jerry
Well mine is the other way, that is the router end of the dust port is way to big for my shop vac so for now I just stuff the beast in there, There are adapters that I have seen I just need to get one someday. Is there any kind of coupler if both are 2 1/2? Just a thought.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 34 (permalink) Old 01-31-2009, 01:39 AM
First Name: Reuel
2-1/2" SHOPVAC Hose Coupler has part no: 906-86-00 (01704 in Melbourne Australia).
Cost AUD$9.90 each. I just bought 2.
Available at Amazon
http://www.amazon.com/Shop-Vac-906-8.../dp/B00004RHKW
reuelt is offline
post #6 of 34 (permalink) Old 01-31-2009, 07:03 AM
AxlMyk's Avatar
It's like every time I buy a tool, the damned dust ports don't interconnect. I even have the SAME fittings purchased at Woodcraft that aren't the same size. Duct tape helps close up some fittings, but it's a real PITA trying to get things connected.
It doesn't need to be a tip, it needs to be addressed by the tool manufacturers to get it right. We shouldn't need to duct tape everything to get things connected.
AxlMyk is offline
post #7 of 34 (permalink) Old 01-31-2009, 09:37 AM
Hi Guys
vac adapters
Here's a link to just some of them,,
the best one is right below,you can cut off what you need and still one or two more for other tools..
http://www.grizzly.com/products/H2443
http://www.grizzly.com/catalog/2009/Main/181
http://grizzly.com/products/2-1-4-x-...-Adapter/G7938
post #8 of 34 (permalink) Old 01-31-2009, 10:25 AM
First Name: Chuck
The Grizzly adapter G7938 wont work. I tried that with Rockler #34654 (same fitting). Problem is the dust port is made to take 2 1/2" hose on the O.D. The I.D. of the port is just under 2 1/4" so that a 2 1/4 shop vac fitting won't go inside. HTH.
Chuck L.
twilite is offline
post #9 of 34 (permalink) Old 01-31-2009, 10:43 AM
First Name: Chuck
The 2 1/2" Shop Vac Hose Coupling won't work either. The I.D. of the coupling fits the 2 1/4" hose ends. The O.D. of the coupling would be about the same as the O.D. of the dust port.
Chuck L.
twilite is offline
post #10 of 34 (permalink) Old 01-31-2009, 10:50 AM
Ralph Barker's Avatar
First Name: Ralph
Mine didn't fit, either. I had an extra hose, though, and just duct-taped it to the Rockler port.
- Ralph
Ralph Barker is offline
Planer dust port Julie Tools and Woodworking 20 02-02-2009 01:06 PM
Rockler Dust Collector Terry Pepper Tools and Woodworking 4 12-21-2008 08:48 PM
Dust Collection Question deck99 Table-mounted Routing 7 04-25-2008 11:11 AM
Dust question Qstick Tools and Woodworking 37 03-05-2007 03:46 PM
