Woodpecker lift issues?? - Router Forums
 6Likes
post #1 of 16 (permalink) Old 09-24-2017, 06:18 AM Thread Starter
First Name: Pat
Question Woodpecker lift issues??
Guys, I bought this lift a couple months ago got it mounted in my existing table very nicely. My issues is that the tension inserts to stop the plate from lifting out had to be removed because I got it really tight. But now that I have been using it for a while when I adjust the lift up it wants to come out. Any solutions for this?
My second issue is probably just me but the ability to make small rough adjustments with the t handle are very crude and I spend way too much time with the fine adjustment wheel to get it right, Any suggestions?
Belg is offline
post #2 of 16 (permalink) Old 09-24-2017, 08:03 AM
hawkeye10's Avatar
First Name: Don
Pat I just bought a Woodpecker table and I know what your talking about. Using the "T" handle is something I hope I will get use to. I have seen on the net that they use to make the lift with a crank handle that comes out the side. There is even a red plastic plug that I think is where it goes. I am going to call them tomorrow and see if they still make it. I think using a crank handle would be much better.
Belg likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 16 (permalink) Old 09-24-2017, 08:30 AM Thread Starter
First Name: Pat
Please let me know what you find out. The unit itself wasn't cheap to begin with and now having to buy something else to get some kind of control would be VERY disappointing.
Belg is offline
post #4 of 16 (permalink) Old 09-24-2017, 11:41 AM
JOAT's Avatar
First Name: Theo
It is issues like that, and more, that made me decide to just go with a router plate I lift out. It pops out, I can quickly, and easily, make any adjustments or whatever, then pop it back in and go.
Personally, if I ever decided I did want a router lift, I would adept a car scissor jack, and go with that. I believe that would be at least as accurate as any store bought lift - and loads less expensive.
JOAT is online now
post #5 of 16 (permalink) Old 09-24-2017, 12:26 PM
hawkeye10's Avatar
First Name: Don
Theo I have heard of people using a car jack. It might do a good job, they sure don't work all that good on cars.
post #6 of 16 (permalink) Old 09-24-2017, 01:09 PM
I have the Jessem lift with the crank out the side and have been using it for years and it sure beats lifting out the router like I used to do. Also have a Rockler lift on the other table and it has a crank from the top that works very well too.
The Jessem dial on the top of the table is graduated in 1/64ths and seems accurate, the Rckler dial is in 1/16ths so a little guessing is involved for smaller increments, but I have no trouble with either, better than in and out of the table to fine tune. Just my opinion, not trying to bash anyone else s,
Herb Stoops is online now
post #7 of 16 (permalink) Old 09-24-2017, 03:42 PM
JOAT's Avatar
First Name: Theo
I don't jack up cars, or mow lawns, any more.
JOAT is online now
post #8 of 16 (permalink) Old 09-25-2017, 03:49 AM Thread Starter
First Name: Pat
Don, I have version 2 of this lift.
Belg is offline
post #9 of 16 (permalink) Old 09-25-2017, 03:49 AM Thread Starter
First Name: Pat
Belg is offline
post #10 of 16 (permalink) Old 09-25-2017, 10:57 AM
Contributor of the Month
First Name: thomas
You have to take the router out of the car first, before you jack it up, don't you ?
thomas1389 is offline
Sold: Woodpecker PRL-V2BD Router Lift jabram Woodworking Classifieds 2 04-07-2017 07:36 AM
Router Lift Issues kbgoodex General Routing 8 05-13-2015 07:07 PM
Woodpecker Lift, Bench Dog Table snmhanson Table-mounted Routing 5 08-15-2011 12:47 PM
Is the Woodpecker QL350 Router Lift Table available? n1edm Table-mounted Routing 9 07-19-2010 01:54 AM
