Single or Double Flute Bits - Router Forums
 6Likes
  • 5 Post By Stick486
  • 1 Post By Cherryville Chuck
post #1 of 6 (permalink) Old 10-16-2017, 04:08 PM Thread Starter
Default Single or Double Flute Bits
Hi
I have done some Internet research but I am still not entirely sure of the pros and cons of single vs double fluter bits.
If I wanted to route a 1/4" channel 3/8 deep in mahogany on my router table - what bit would be best for the job?
This is not a repetitive task, only once every three months, channel length is about 12"
Regards
J
John Charnock is offline
post #2 of 6 (permalink) Old 10-16-2017, 04:44 PM
I would use a 3 or 4 flute spiral bit...
and it'd be a Freud or Whiteside...
FWIW.. more flutes last longer, cut cleaner, cut cooler, less burning and have better balance...
post #3 of 6 (permalink) Old 10-16-2017, 07:48 PM
Single flutes can cut faster but finish is usually rougher. And it may run rougher in the router. An up it spiral will clear chips better but may leve rough edges at the top of the channel. If you are covering the channel then it doesn't matter.
Danman1957 likes this.
post #4 of 6 (permalink) Old 10-16-2017, 08:17 PM
CharleyL's Avatar
First Name: Charley
I'll echo the others. Single flute bits vibrate and do not produce good smooth cuts. Get bits with 2 or three cutting edges. They do a much better job. Most of what I have are 2 flute bits, but I have a few with three or more flutes and prefer them when I need the smoothest cuts. The Freud Quadra Cut bits are great.
Charley
Central North Carolina
CharleyL is offline
post #5 of 6 (permalink) Old 10-16-2017, 09:23 PM
hawkeye10's Avatar
First Name: Don
If Whiteside or Freud make it you don't have to worry about the rest.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 6 (permalink) Old 10-16-2017, 10:08 PM
dovetail_65's Avatar
First Name: Dovetail
In my experience the only time a single flute can be used on smaller hand held router with little to no vibration is the O flute design in the 1/8" size(1/4" is pushing it) and used on soft wood or plastic.
I have some 1/2" single flute combination bits and boy they act weird, The only router I can use them on is my huge Festool OF 2200, all the other router just vibrate too much using the larger single flute bits. I won't buy anymore 1/2" regular single flute ever again though, but they do work nice enough with the big router(still feel weird and sound even worse).
Now on a CNC it doesn't matter the single flute work great, but for hand, held especially for newbs, I would never suggest a single flute larger than 1/4"(try to stick to 1/8"). Even then try to stick to those O flute versions. With CNC the single O flute work great in almost any size on many materials, even on aluminum.
dovetail_65 is offline
First bit set Mike Router Bits - Types and Usage 46 07-29-2015 08:56 AM
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
Router bit testing Mike Router Bits - Types and Usage 21 12-17-2014 09:42 AM
Shorter High quality Bits? Machinst_Anthony CNC Routing 7 11-27-2012 03:02 PM
Rate your personal experience with router bits ... riffin-rich Router Bits - Types and Usage 36 05-23-2011 07:43 AM
