Inside cuts on the RW plate - Router Forums
post #1 of 7 (permalink) Old 02-07-2009, 01:47 PM Thread Starter
beemerbob's Avatar
First Name: Robert
Default Inside cuts on the RW plate
I want to make a wooden copy of my Vacu-Plate. How are the mounting slots duplicated
Bob from Northwest Florida
beemerbob is offline
post #2 of 7 (permalink) Old 02-07-2009, 02:39 PM
Hi Bob
This is one of the times a picture is worth a 1000 words, can you post a picture of the Vacu-Plate you are trying to copy...?
But I will say a ski jig can put slots in easy and quick and safe
post #3 of 7 (permalink) Old 02-07-2009, 08:01 PM
xplorx4's Avatar
First Name: Jerry
Greetings Robert and welcome to the forum good to have you aboard.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 7 (permalink) Old 02-07-2009, 10:55 PM
TWheels's Avatar
Is your vacu-plate an Oak-Park plate?
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #5 of 7 (permalink) Old 02-08-2009, 07:33 AM Thread Starter
beemerbob's Avatar
First Name: Robert
Yes it is. Sorry about no picture for the original post. Have had a bunch of 'dumb' when I have tried it before.
I think I can figure out the mounting bolt holes on a plate, How do you do the rectangles?
post #6 of 7 (permalink) Old 02-08-2009, 08:00 AM
Hamlin's Avatar
First Name: Ken
Hi beemerbob,
Cutting the slots are relatively easy. The ski method would work and so would the "stick" method.
http://www.routerforums.com/general-...-op-plate.html
Ken
"A VETERAN"
Hamlin is offline
post #7 of 7 (permalink) Old 02-08-2009, 09:07 AM
HI Bob
Ken is right about the ski jig . the slots can be tricky,because they are not parallel to the sides of the plate....a pattern bit will do most of the work but you need a way to hold the plate down and use the hold down board to line up the slots to the outside of the hold down board...you can use two bits a V bit and a standard bit for the slots.....
This is how I would do the job, 1st.cut the plate to size,then put in the vac.ports,then drill the holes for mounting the router then screw it down to a hold down board with the holes for the router mounting so the slots are parallel to the edge of the hold down board, then make a ski jig or use your edge guide for your router with stop blocks on both ends of the slot..use a 3/16" router bit for the slots and a V bit to put in the 82 deg.slot...
I have the router bits below that lets me do that type of job in one or two passes ..
Screw Slot Router Bits
http://www.mlcswoodworking.com/shops...screw_slot.htm
Pattern/Flush Trim Bits
http://www.mlcswoodworking.com/shops...n_flush_anchor
Name:	oak park plate.jpg
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Marvel 40 Router Plate cbsjoez1935 General Routing 2 04-06-2009 05:23 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
