Triton TRC001 questions - Router Forums
 7Likes
post #1 of 11 (permalink) Old 12-19-2017, 06:23 PM Thread Starter
First Name: Joe
Default Triton TRC001 questions
I purchased a Delta table saw set up that has a torsion base and a router extension built in. It also included a Triton TRC001 router attached to an Incra insert. It looks like it just came out of the box. I can't find a manual for the unit and I'm not sure what the hp rating is. I don't see any way of raising or lowering the router other than taking the plate off and making the adjustment and reinserting the plate. The router seems like a beast that can pretty much cut through anything but it is a pain in the butt to adjust. I have a TRA001 manual and it shows a way to adjust it when mounted. Is the TRC simply not made to be adjusted in the table. Should I just go out and buy another router that will fit in a lift and scrap this one?
Joe
JoeR3451 is offline
post #2 of 11 (permalink) Old 12-19-2017, 07:10 PM
DonkeyHody's Avatar
First Name: Andy
Here's a link to the owner's manual for the TRC001.
https://www.tritontools.com/Helpers/...754_Manual.pdf
Be sure the spring has been removed from the plunge mechanism per the instructions. You may need to drill a hole in your insert plate for the winding stem to go through. But even if you only adjust from underneath, it should be easy if the spring is removed.
Don't scrap that one. I'll give you $50 for it, sight unseen.
DaninVan likes this.
DonkeyHody is offline
post #3 of 11 (permalink) Old 12-19-2017, 08:17 PM Thread Starter
First Name: Joe
Hi Donkey,
Thanks but that's the link to the TRA001. I've got that manual. Problem is where it shows the winding stem attaches to the router doesn't exist on the TRC. I attached a photo of where the TRA manual says the winder goes, so you can see the problem. I think it's just that this router predated the TRA and doesn't have the hole in the bottom to insert the crank.
Joe
JoeR3451 is offline
post #4 of 11 (permalink) Old 12-19-2017, 09:04 PM
It took a little searching to realize the TRC 001 was an earlier model. I found info on its use from 2004. One Year Later, Triton Router TRC-001 Review
More info here, addressing some of your issues. OnlineToolReviews.com - Triton TRC001 3.25HP Router Review
Couldn't find an instruction book. Are you sure your TRC actually has an above table crank? Some early 3.25 hp models didn't have this feature.
You might write to Triton to see if they still have a pdf version of the manual. Send the serial number and model number so they can get the correct version of the manual--if they still have one.
post #5 of 11 (permalink) Old 12-19-2017, 09:08 PM
DonkeyHody's Avatar
First Name: Andy
Originally Posted by JoeR3451 View Post
Hi Donkey,
Joe
OOps, I searched for the TRC and didn't notice that it took me to TRA. Guess that's why it looks so much like my TRA. Still, check to be sure the spring has been removed.
post #6 of 11 (permalink) Old 12-19-2017, 09:44 PM Thread Starter
First Name: Joe
Hi Tom,
Looks like this model didn't have the above the table crank.
Joe
JoeR3451 is offline
post #7 of 11 (permalink) Old 12-20-2017, 06:46 AM
TenGees's Avatar
First Name: Paul
Nice looking set-up, hope you can solve your issue, Joe.
TenGees is offline
post #8 of 11 (permalink) Old 12-20-2017, 09:30 AM Thread Starter
First Name: Joe
Thanks Paul,
I got a great deal on it but then I moved from a 3 car garage (in which I put a 100 amp sub panel lots of 120 and 240 v lines) to a 2 car garage. :-( It fits but just barely. Especially with mama's suv and my '46 Chevy flatbed. Oh yeah and the Harley. Time to go find a small warehouse to rent, lol.
Joe
JoeR3451 is offline
post #9 of 11 (permalink) Old 12-20-2017, 10:15 AM
"Time to go find a small warehouse to rent, lol."
-Joe
For the vehicles...
DesertRatTom and TenGees like this.
DaninVan is online now
post #10 of 11 (permalink) Old 12-20-2017, 11:53 AM Thread Starter
First Name: Joe
-Joe
For the vehicles...
No, I'd rather be in the warehouse with the tools than in the garage where I'm always interrupted with "honey dos" LOL
JoeR3451 is offline
2 Triton related questions bigbit Table-mounted Routing 11 06-03-2013 06:50 AM
Triton TRC001 Parts in the USA Shortslvs General Routing 9 02-15-2013 12:16 AM
Triton TRC001 Vs. Porter Cable 890 series weedsnager Table-mounted Routing 29 11-07-2011 08:58 PM
For Sale: Triton TRC001 3-1/4 HP Router oldhippie1951 Woodworking Classifieds 0 08-15-2011 01:30 PM
Greetings, Triton Router questions woodmaker7 General Routing 3 11-23-2010 01:14 PM
