router bit climbing out of the collet - Router Forums
 11Likes
post #1 of 26 (permalink) Old 02-16-2018, 01:56 AM Thread Starter
Country: New Zealand
First Name: Peter
Unhappy router bit climbing out of the collet
Hi all, new to this place, I felt inspired to join up because I've recently acquired a nice Bosch GOF 1600 CE router and bought the fixed base
for this router from Amazon.
The fixed base I installed into my homebrew router table.
Currently I am building a new kitchen and I'm using Blum hardware that requires me to rout a 38mmx8mm rebate (rabbet I think in American?)
into the drawer bottoms.
Put an 18mm router bit with a 1/2" shaft into the fixed router base that's sitting in the table. Started making some cuts, around 16mm wide by
8mm deep. It worked fine for a while, when, suddenly, the router bit emerged from the top surface of the work!
Imagine my surprise. Just glad I didn't have my hand anywhere near.
This is not the first time it's behaved like that. The first time it happened I assumed I might not have tightened the collet sufficiently. I also
cleaned collet and router bit shaft with acetone, in case of oil or other lubricants. That time I was able to finish the job.
But twice? That is no longer an accident. I checked, the collet was really tightly torqued up.
I'd made about 8 or 9 cuts without a problem, when suddenly the bit started climbing, and it climbed 8mm (3/8") over a stretch of 200mm (8").
That's rapid!
It still was as tight as I can get it when I dropped the motor out of the table and checked the collet. But, having said that, I was able to gently
tap the bit back into the motor with a piece of 4x3 that I had lying on the workbench.
I simply don't know what's going on with this. Is it the collet? Is it my technique of using nearly the full width of the router bit (I was cutting with
the end-face of the router, and not with the side, running the sheet of mdf over the table)?
(please don't ask if I was using a 10mm router bit in a 1/2" collet -- I am not THAT clueless ).
P.W.H. is offline
post #2 of 26 (permalink) Old 02-16-2018, 04:01 AM
a little reading on collets..
Danman1957 and dicktill like this.
post #3 of 26 (permalink) Old 02-16-2018, 05:08 AM Thread Starter
First Name: Peter
Thank you for the links. Unfortunately, nothing in there that would be new to me - and I do keep things clean, and I know not to insert the bit all the way to the cutter head.
Don't forget that the router is very new; it's maybe clocked up 1-2 hours of running time all-up. Wear and tear and buildup of crud is unlikely to be the culprit.
One of those files mentioned resin leaving discoloration ... and I had some discoloration ... but, realistically, no resin or dust should be able to get between the collet and the bit
during operation (without a bit change). Some dust may have got into the slots and then smeared across the shaft when the bit started to slip. Which is the thing that should NOT
have happened.
Heat - is it possible that the spindle could expand from the heat of frequent cutting? The nut should hold things together one would assume.
-Peter
P.W.H. is offline
post #4 of 26 (permalink) Old 02-16-2018, 05:31 AM
imported aka chinese less than stellar bit w/ an out of spec shank..
whimsofchaz, jj777746 and P.W.H. like this.
post #5 of 26 (permalink) Old 02-16-2018, 05:55 AM
hawkeye10's Avatar
First Name: Don
I Peter and welcome. I have a Chinese bit that I can hardly get in my collect and I can hardly get it out. So like Stick said that might be a problem. You could also take the router back or call the manufacturer.
P.W.H. likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 26 (permalink) Old 02-16-2018, 06:28 AM
difalkner's Avatar
First Name: David
Welcome to the forum, Peter! I have never had that happen so not much help from me on this one. I do hope you get it resolved - could be dangerous! You can post photos if they're on your computer, btw.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 26 (permalink) Old 02-16-2018, 07:14 AM
DonkeyHody's Avatar
First Name: Andy
I too, suspect it's the bit. Try other bits and see if they slip too.
jj777746 likes this.
DonkeyHody is offline
post #8 of 26 (permalink) Old 02-16-2018, 08:03 AM
Nickp's Avatar
First Name: Nick
Can you put a caliper on that bit and measure the shank...?
Nick
Nickp is online now
post #9 of 26 (permalink) Old 02-16-2018, 08:21 AM Thread Starter
First Name: Peter
Thanks, going to put the calipers on the shank tomorrow. Maybe that will give me a clue.
Doesn't really explain why it would work just fine for a while and then suddenly start shifting out.
But yes - the collet was very tight after the incident, yet I could tap the bit back into the collet with a piece of softwood,
so it was NOT firmly held in the vertical.
P.W.H. is offline
post #10 of 26 (permalink) Old 02-16-2018, 08:24 AM
Nickp's Avatar
First Name: Nick
Could it be possible that you might have had some "new-bit-goop" on it when you started...? Or some goop in the collet from a previously used new bit...?
Nick
Nickp is online now
Adapt 1/4" router collet to 1/2" bit brian129 Router Bits - Types and Usage 22 02-13-2013 07:21 PM
vocabulary? jayt85331 New Member Introductions 13 10-25-2011 09:40 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Ridgid Router Easy Above Table Bit Change shawnpatt Table-mounted Routing 1 03-06-2009 04:58 PM
