Remote Digital Readout - Router Forums
post #1 of 1 (permalink) Old 03-07-2009, 02:01 PM Thread Starter
scotirish10's Avatar
First Name: Ronald
Thumbs up Remote Digital Readout
A few days ago someone asked if the "Wixey" digital readout is w worthy thing to buy. I ordered one and received it yesterday. I mounted it on my router and put the readout unit on the wall behind the router table. Installation was easy, even though I had to modify the way the said to install to accommodate my router lift. I have a "Jessem" lift and table. The pictures will show more.
First picture: Basic unit at start.
Second & Third pictures: Used mounting screw from base to mount base unit.
Fourth & Fifth pictures: Used a longer screw than came with unit to reach the hole I drilled in the aluminum lift base.
Sixth picture: Mounted the readout unit on the wall behind the router table.
Tried it out and it was right-on the money.
I am looking forward to using this with my "Daisey" pin router attachment.
scotirish 10
Work safe: Remember the only 'SAFE' power tool in the shop, is the one with the plug pulled out of the socket!
If you have an open mind is there a chance your brain might fall out?
scotirish10 is offline
Smartlift Digital Router Lift rmaxa General Routing 18 12-20-2009 10:33 PM
A wixey for your lift Gene Howe Table-mounted Routing 6 03-04-2009 10:19 AM
Milwaukee 3-1/2 HP EVS with remote newinwood Table-mounted Routing 7 01-04-2009 10:19 PM
Remote PC 7518 speed control mntbighker Table-mounted Routing 5 01-02-2008 10:43 PM
Remote Motor control bobj3 Lobby 0 01-04-2007 11:32 AM
