Groove Question - Router Forums
 6Likes
post #1 of 30 (permalink) Old 02-24-2018, 10:05 PM Thread Starter
First Name: Joe
Default Groove Question
I知 trying to make an inch wide groove in a piece of wood to hold a shelf. Right now I知 using half inch bit. Whenever I try to do more than an 1/8inch depth the cut messes up. Is there a simpler way to make an inch groove? How do you make grooves on your table?
Jesus was a wood worker and people liked Him, maybe there's hope for me too.
Peace
Pastorshobby is offline
post #2 of 30 (permalink) Old 02-24-2018, 10:15 PM
mimac's Avatar
First Name: Brian
I would use a dado blade on a table saw. If you are using a router in a router table setup and your cut is wandering make sure you're feeding in the right direction and you are using hold-downs and feather boards.
mimac is online now
post #3 of 30 (permalink) Old 02-24-2018, 10:20 PM
Semipro's Avatar
First Name: John_*
Joe ? Is your shelf a 1 thick, and how deep do want the groove to be?
Are using some kind of guide system, does the 1/2 bit have a bearing or are using a template guide? How long is the groove?
Thank You John
Semipro is online now
post #4 of 30 (permalink) Old 02-24-2018, 11:20 PM
w/ grain or cross grain..
and describe the mess up..
Ray Newman likes this.
"SNORK Mountain Congressional Library and Taxidermy
post #5 of 30 (permalink) Old 02-25-2018, 08:35 AM
First Name: Ken
It may be more of an investment than you want to make at this time, but Eurekazone.com makes what they the Super Smart Routing Kit which works with their Track Saw Guide Rails. You provide your own router - usually a plunge router is used.
The available rail stops allow you to cut exact width and length dadoes & rabbets with smaller router bits. Watch the video to get a sense of it. Think hand-driven CNC router.
KennK is offline
post #6 of 30 (permalink) Old 02-25-2018, 10:06 AM
First Name: 4D
My guess is that the pastor was using a straight edge, but running the wrong direction against it. Not hard to overcome when the depth was only 1/8", but too hard to keep against the fence when the load/depth increased.
Always move away from you with the fence on the left. Toward you with the fence on the right.
4D
4DThinker is offline
post #7 of 30 (permalink) Old 02-25-2018, 11:06 AM
Sounds like you're trying to feed the board into the bit by moving the board. Generally a dado like this should be cut by running the router across the board using some sort of guide clamped to the workpiece.
The following video is on how to make a jig called an exact fit dado jig, which allows you to easily make perfect dados with the router. It is reusable. Next best way to make them is with a table saw, be even there you will find it requires a jig to reliably make the cut 90 degrees to the edge of the board.
Here's the video. Pay particular attention to how carefully he set the glued pieces 90 degrees to the longer guide pieces. And notice that he took pains to make sure the guide edge is dead flat. You will be using a half inch trim bit, maybe 3/4 inch long with a bearing at its base. Attached is a picture of such a jig and small mortising bit with half inch shank.
Name:	exact width dado jig diagram.jpg
MT Stringer likes this.
post #8 of 30 (permalink) Old 02-25-2018, 12:00 PM
more on feed direction....
post #9 of 30 (permalink) Old 02-25-2018, 07:08 PM Thread Starter
First Name: Joe
I知 routing cross grain in the correct direction with feather boards. The blade cuts out and moves the wood messing up the straight line. I tried it again and my next pass was okay
Peace
post #10 of 30 (permalink) Old 02-25-2018, 07:10 PM Thread Starter
First Name: Joe
4D
I think it痴 the opposite you always more right to left, I think?
Peace
Groove and Tennon Joint Construction neville9999 General Routing 3 11-19-2013 10:15 AM
bit question - inside groove, advice plz... rpludwig Router Bits - Types and Usage 16 12-12-2011 12:37 PM
Howdy! and a tongue and groove question rickbob New Member Introductions 8 12-03-2010 01:03 PM
Tongue & Groove Ceiling Question wyatt earp Project Plans and How To 10 04-06-2010 08:26 AM
