What bit? - Router Forums
 6Likes
  • 5 Post By Stick486
  • 1 Post By Putttn
post #1 of 6 (permalink) Old 03-04-2018, 10:30 AM Thread Starter
First Name: BILL
Default What bit?
I have to elongatee two holes in melamine and wonder what bit would be the best to accomplish without chipping?
Putttn is offline
post #2 of 6 (permalink) Old 03-04-2018, 10:56 AM
down shear after you hog out the piece w/ your jigsaw..
BrianS, JFPNCM, Danman1957 and 2 others like this.
post #3 of 6 (permalink) Old 03-04-2018, 12:47 PM
Rebelwork Woodworking's Avatar
First Name: Jack
A plunge bit and a pattern would be your best bet...
http://www.jackdurencabinets.com/homepage.htm
Rebelwork Woodworking is offline
post #4 of 6 (permalink) Old 03-04-2018, 12:58 PM Thread Starter
First Name: BILL
Have a router table setup but haven’t purchased a plunge router.
Putttn is offline
post #5 of 6 (permalink) Old 03-04-2018, 01:05 PM
vchiarelli's Avatar
First Name: Vince
Cut out most of the waste with a jig saw then use a template mounted to the bottom of your work piece and a pattern bit mounted to your router table. It really depends on the size of your work piece as far as handling it. You don't need a plunge router to do this handheld - a fixed base will work. You only need to set the depth of the bit so that the bearing rides along the template, but hand held, you would mount the template to the top of the work piece.
vchiarelli is offline
post #6 of 6 (permalink) Old 03-04-2018, 01:31 PM Thread Starter
First Name: BILL
That sounds like it will work. I do have a top mounted pattern bit I recently purchased and that configuration will work on my table.
vchiarelli likes this.
Putttn is offline
spiral bit for cutting plywood calneva Router Bits - Types and Usage 11 09-28-2017 06:25 PM
Glue Joint Router bit Setup on stock pooch692000 Router Bits - Types and Usage 5 12-02-2016 05:32 PM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
