Bosch RA 1171 - Router Forums
post #1 of 9 (permalink) Old 03-09-2018, 11:43 AM Thread Starter
Default Bosch RA 1171
Does anyone know if the Jessem Router lift 2 plate will fit the opening in the Bosch RA 1171 router table without modifying the opening? Thank you for sharing your knowledge.
Michael C is offline
post #2 of 9 (permalink) Old 03-09-2018, 01:49 PM
just use a stand alone 1617 fixed base...
post #3 of 9 (permalink) Old 03-10-2018, 12:30 PM
Stick's suggestion is great. You can order a key (as in the pictures), so you can adjust the height from above the table. You remove the base of the router.
According to the following listing, the plate is pre setup for the fixed base. "
Compatible with the following router models:
Bosch: 1617 series (fixed base only), 1613, 1619, MR Series
post #4 of 9 (permalink) Old 03-22-2018, 01:42 PM
pusserboy's Avatar
First Name: Stuart
Would the Porter Cable 690 LR router fit in this base as well
Stuart
pusserboy is offline
post #5 of 9 (permalink) Old 03-22-2018, 01:45 PM
Stuart
the PC router fit into the Bosch base??? is this what you are asking...
NO!
post #6 of 9 (permalink) Old 03-23-2018, 08:49 PM
First Name: Earl
Stuart
YES, according to page 15 of the RA1171 instruction manual listing compatible routers. While the Bosch 1617 uses a 4 screw pattern for its sub-base plate, under that plate is a second set of tapped holes in the PC 690 trianglular pattern. Using the "B" mounting configuration, you should be able to match up either the 1617 or the 690.
By tapping the triangle pattern, the 1617 fixed base can use any attachment/fixture drilled for the PC 690, adding to its versatility. (I think the PC 7580 uses the same pattern? Really, i'll stick with my 1617's!!) See the photo below.
earl
greenacres2 is offline
post #7 of 9 (permalink) Old 03-23-2018, 09:03 PM
I believe the OP wanted to know if the 690 motor would fit into the 1617's fixed base not the table...
post #8 of 9 (permalink) Old 03-23-2018, 10:16 PM
old55's Avatar
First Name: Ross
Welcome to the forum Mike.
Ross,
old55 is offline
post #9 of 9 (permalink) Old 03-24-2018, 11:12 AM
First Name: Earl
That would definitely be no.
earl
For Sale: Bosch 1171 Router Table for sale phillipdanbury Woodworking Classifieds 2 04-07-2014 10:51 AM
Bosch table...RA 1171 or RA1181 Brett K Table-mounted Routing 4 12-17-2012 09:41 PM
Oak park box jig on Bosch 1171 table RegisG Table-mounted Routing 13 10-14-2011 08:47 PM
Sold: Bosch 1171 benchtop router table 3thumbs Woodworking Classifieds 5 04-11-2010 09:30 PM
Bosch RA 1171 Routing Table Evelinda Table-mounted Routing 13 10-20-2008 09:14 AM
