Collet problem - Router Forums
 16Likes
post #1 of 27 (permalink) Old 03-12-2018, 08:08 PM Thread Starter
jj777746's Avatar
Default Collet problem
1/2 inch bit shank wont go all the way in. Haven't used my 3 1/4 HP Triton Router for some time & yesterday I was setting up to start working again but the bit shank still had about 1/4 inch to go in,but wouldn't .I cant remember this happening before & noticed this situation when I went to raise it 1/8 from the bottom of the collet.The router has been installed in my table ever since I got it.
I pulled the bit out & with a torch checked for foreign body & junk but apart from a little sawdust there was nothing to cause this problem. Has anyone ever seen this before or have I finally lost the plot? Jamesjj
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #2 of 27 (permalink) Old 03-12-2018, 08:22 PM
Semipro's Avatar
First Name: John_*
James check the bit also may have small burr on it.
Take the collet out of router and see if the bit will slide thru.
Semipro is online now
post #3 of 27 (permalink) Old 03-12-2018, 09:33 PM
time to clean everything...
gmercer_48083 and gjackson52 like this.
post #4 of 27 (permalink) Old 03-13-2018, 08:49 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I really can't imagine what, other than debris, could cause this to happen James. The complete cure for all time is to replace the chuck with a MUSCLECHUCK, it makes bit change from the top even easier, plus only a 4mm ball ended Allan key is required to lock/unlock the bit and it is held with a grip several times that of a collet chuck .
As a matter of interest, if you turn to page 5 of the TRA001 hand book, you will see that it reads: "NOTE: When fitting cutters, ensure the shank is inserted fully into the collet"
Harry
harrysin is offline
post #5 of 27 (permalink) Old 03-13-2018, 06:03 PM Thread Starter
jj777746's Avatar
Thank you Harry,I'm about to purchase a Musclechuck for my Bosch router. Must see if it is interchangeable with the Triton. Will clean the collet out & get back to you.Thanks again,Jamesjj
jj777746 is offline
post #6 of 27 (permalink) Old 03-14-2018, 12:06 AM
harrysin's Avatar
First Name: Harry
So far as I know James Bosch takes a #4, the old* Triton the #11 and the new Triton the #8
* The old Triton does NOT have above table height adjustment whereas the new one does.
Harry
harrysin is offline
post #7 of 27 (permalink) Old 03-14-2018, 01:01 AM Thread Starter
jj777746's Avatar
Thanks again Harry.I blew the dust out & wiped everything nice & clean & it's like new again.Also try-fitted a couple brand new unused bits & all is good. Wont need a Musclechuck for the Triton but definitely will for the Bosch.The "fly in the ointment"there is,the Bosch came with three collets but no half inch size.Jamesjj
jj777746 is offline
post #8 of 27 (permalink) Old 03-14-2018, 01:20 AM Thread Starter
jj777746's Avatar
John & Stick,thanks for your advice.Wasn't that much dust in the collet but just enough to cause a problem.All good again & to make sure it stays that way I stuffed a piece of rag (cheese cloth)down the table insert plate hole to stop any foreign object entering the collet. Jamesjj
jj777746 is offline
post #9 of 27 (permalink) Old 03-14-2018, 02:58 AM
harrysin's Avatar
First Name: Harry
"the Bosch came with three collets but no half inch size.Jamesjj"
I'm very surprised that there wasn't a 1/2" collet, I'm sure members more familiar with Bosch will jump in here.
jj777746 likes this.
Harry
harrysin is offline
post #10 of 27 (permalink) Old 03-14-2018, 04:57 AM Thread Starter
jj777746's Avatar
Default Bosch Router collet missing
Hi All,My Bosch Router came with no 1/2inch collet.I cant find any advice as to the reason .It has 3 collets ,1/4inch being the only one I have used, & 2 smaller collets.The model is POF1200 AE 240V,50hz,1200watts.IMO I don't think a 1/2 inch bit would fit in this particular model.Could someone offer a "bit" of advice about this router please & will I be able to buy a Musclechuck to fit it?? Thanks, Jamesjj
jj777746 is offline
Triton TRA001 Collet Problem jackson74 General Routing 4 02-10-2015 11:42 AM
Searching for a collet? Mike General Routing 12 06-21-2013 07:30 AM
collet problem in Freud FT 2000E dustyiniowa General Routing 4 01-22-2012 09:23 PM
Makita 3612C collet problem W C Slad General Routing 10 01-16-2012 09:53 AM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 06:50 AM
