Nylon Fence? - Router Forums
post #1 of 9 (permalink) Old 03-16-2009, 09:55 AM Thread Starter
First Name: Doc
Default Nylon Fence?
I was wondering where I might get the nylon fence that I see on the Router Workshop shows? It is the one that they clamp on to the router table. It is white and appears to be made of nylon.
Thank you
doctordun is offline
post #2 of 9 (permalink) Old 03-16-2009, 10:07 AM
Hi doctordun
You can get it from OP or Ptree
http://www.ptreeusa.com/uhmwproducts.htm
You will need to call OP it's not listed as a item they sale with out buying the system.
I do recommend Ptree, buy the wide stuff and then you can cut it down to size on your table saw...in that way you will have more than one.
Thank you
post #3 of 9 (permalink) Old 03-16-2009, 12:01 PM
allthunbs's Avatar
First Name: Ron
Thank you
Hi Doctordun: It is called Ultra High Molecular Weight (UHMW) polyethylene and is available anywhere plastic is sold. It is a commodity so shop around. On any given day you'll have a variety of prices.
Hope this helps.
Allthunbs
allthunbs is offline
post #4 of 9 (permalink) Old 03-16-2009, 12:36 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums doctordun.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 9 (permalink) Old 03-16-2009, 04:47 PM Thread Starter
First Name: Doc
Thank you very much for the fast replies.
Doc(my nickname also)
post #6 of 9 (permalink) Old 03-24-2009, 09:01 PM
Hope this helps.
Allthunbs
be carefull with UHMW it tends too be unstable....temp. changes can make it move around...im a tool and die maker,when ever we machine the stuff we have too be careful with higer tolerances.UHMW will changs sizes on ya after it sits for awhile.........this may not make a differance in the aplication were talking about here but just keep it in mind.
CSORTMAN0402 is offline
post #7 of 9 (permalink) Old 03-24-2009, 09:08 PM
allthunbs's Avatar
First Name: Ron
Hi Chris: interesting comment. Typically I use it for a fence on a router table because I thought it was stable. Under what conditions does it go haywire >90 degrees F? Or, >60 F?
Unaffected by humidity? What about impact.
Pain in the but to bond/glue but fine for mechanical fasteners?
Input appreciated - vacuum happening here.
Allthunbs
post #8 of 9 (permalink) Old 03-25-2009, 07:51 AM
First Name: Richard
Welcome to the Forum Doc: Those fences are available from Oak-Park, They come in different lengths. The also sell the jointer fence, made out of the same stuff. That is the fence that has the output side of the fence wider than the input side. Hope this helps.
Woodnut65
Woodnut65 is offline
post #9 of 9 (permalink) Old 03-25-2009, 10:51 AM
Hamlin's Avatar
First Name: Ken
Hi Doc,
Welcome to the forums.
You can find the OP fences here:
Oak Park Enterprises Ltd.: Catalogue
Ken
"A VETERAN"
Hamlin is offline
Face Lift for the Router Fence bobj3 Jigs and Fixtures 8 04-07-2013 09:21 AM
Some Thoughts on Fence Control Gilbear Table-mounted Routing 21 04-16-2010 05:38 PM
Pivoting fence arc vs distance? Bogydave Table-mounted Routing 16 01-14-2009 08:49 PM
Very Long Pivot Fence mcelduff Table-mounted Routing 2 01-12-2009 07:41 AM
Perpendicular fence tauras Table-mounted Routing 1 10-12-2008 09:46 AM
