Help, bit climbing up the wood??? - Router Forums
post #1 of 15 (permalink) Old 03-30-2018, 11:00 AM Thread Starter
Default Help, bit climbing up the wood???
Completely new to woodworking, just got a bunch of tools from my gf's mom's basement... Most of it is brand new. I watched a few videos on using a routing table and wanted to do a simple project, trying to make a dice box for tabletop gaming. My plan was to cut a square and 4 sides and cut them all to 45deg angles and glue it all together.
The whole process is kicking my butt, but I got 2 nice smooth "square" bottoms cut and matched up sanded the edges so they are nice and smooth and ready to angle the edges. Then I ran the first one through the router... did the first pass on one side and it went okay had a small issue with one of the guards being slightly out of line and put a small gouge in the wood when it bounced on the bit. On the second side of the square I started hearing different sounds and knowing how dangerous these things can be I stopped the table and looked at the wood. The 45deg angle rode up the side of the wood like a ramp, very subtly but enough to leave uncut wood on the table side of the piece.
I took a minute to look over the router and made sure things were tight and moved the adjusted the height of the bit and tried on the 2nd piece of wood. My results are as follows... (assuming the pictures work) What the heck is happening, whats it called, and any links to solutions would be great. I dont even know what to call this or what the term for the problem may be so looking it up before asking is hard.
TLKBones is offline
post #2 of 15 (permalink) Old 03-30-2018, 11:27 AM
Is the collet tight, did the bit move up in the collet, or did the whole router move up, is the router motor locked during the cut?
You need to back up the cut to eliminate tear out at the end of the cut too. Use a backer board to push the piece through.
If the bit moves up and the collet was tight, make sure the collet and bit are the same diameter. Sometimes metric collets and 1/4" bits get mixed up.
Herb Stoops is online now
post #3 of 15 (permalink) Old 03-30-2018, 11:39 AM
Welcome to the forums N/A...
Looks like the bit climbed... it may be loose...
what you are experiencing isn't climb cutting... (see the PDF's)
also the material appears to be too thick for the bit's capacity......
over the next several posts are some PDF's.. please take the time to read them..
post #4 of 15 (permalink) Old 03-30-2018, 11:40 AM
File Type: pdf R5 Climb-Cutting Versus Chip-Cutting.pdf (176.1 KB, 29 views)
File Type: pdf Routing for Beginners - Lesson - 3.pdf (856.1 KB, 20 views)
post #5 of 15 (permalink) Old 03-30-2018, 11:41 AM
Name:	GUIDE BUSHINGS.jpg
Name:	GUIDE BUSHING - TEMPLATE.jpg
post #6 of 15 (permalink) Old 03-30-2018, 12:43 PM
Hi, the 45 degree joint is called a miter cut and is a genuine PITA to get just right, with opposite sides exactly the same length. That's + or - 0, exactly 45 degrees. If cut on a table, you can use a 45 degree bit that's at least 7/8ths tall.
IF you bottom out the shank of the bit, it can creep. Also, many collets tighten up, then resist, then you tighten a little more and they break loose. A final tightening is needed to hold the pit in place, however, not all brands do this so try it out first. I drop a 1/2 inch grommet in the collet so the bit bottoms on that, not the steel shaft.
Most routers have some lever to lock them in position (depth). If it's not tightened, it will creep. Check the instruciton book if you have it.
Hope that's helpful. Woodworking is a great past time. Hint, make stuff for your lady fairly often and she'll back you up when it's tool or accessory time.
DesertRatTom is online now
post #7 of 15 (permalink) Old 03-30-2018, 12:44 PM
I see Stick posted his collection of pdfs. Huge amount of helpful information there.
post #8 of 15 (permalink) Old 03-30-2018, 12:52 PM
Hey, TLK; welcome!
If you don't have the manual, there's a manual section here with a pretty good selection to download from.
DaninVan is offline
post #9 of 15 (permalink) Old 03-30-2018, 05:50 PM Thread Starter
Thanks for the help, I also read somewhere that new bits can have some goo on them, these are brand new and have some sort of oil on them. Ill clean everything off/out and make sure it get it tight tomorrow when I pull stuff out again.
Also, Im trying to cut the square wood out of a large piece with a hand saw, like a circular but small and a 3 3/4 blade, has a spring loaded plate the blade goes down through... Been just clamping wood to the side of the table in the picture and putting an 90deg ruler against the fence and clamping it down the for plate on the saw to follow. Any better suggestions?
TLKBones is offline
post #10 of 15 (permalink) Old 03-30-2018, 05:55 PM
vchiarelli's Avatar
First Name: Vince
@TLKBones - Welcome to the forum
First things first: in your first picture, is the bit set when you attempted this or is this after the cut?
Did you intend to keep that flat surface at the bottom of the 45 or did you intend to miter to 45 from top to bottom?
I see a couple of things that concern me and this is how I would fix them:
make sure the bottom of the cutter is even with the table top/bottom of your work piece
slide your fence towards your work piece and use the fence to guide the cut so that you don't take a full cut
then slide the fence back and do it again, taking another small cut
lastly, use a straight edge and line up the bearing on the bit with the fence, both infeed and outfeed and make your final cut
Also, use a feather board attached to the fence so that it holds the work piece flat on the table and doesn't allow the work piece to ride up - you can attach a feather board on both sides of the bit with some clamps and don't let the feather boards touch the bit, making sure the clamps are out of the way of your work piece
vchiarelli is offline
router bit climbing out of the collet P.W.H. Table-mounted Routing 25 03-13-2018 09:00 AM
Xmas - I got a Triton TRA001....now what table? mikeyo76 New Member Introductions 10 12-26-2017 04:13 PM
Make an old wood floor look a bit better??? JudgeMike The Finishing Touch 11 11-18-2014 05:13 PM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
