Routing Cocobolo - Router Forums
post #1 of 10 (permalink) Old 03-18-2009, 05:01 PM Thread Starter
SteveSawDust's Avatar
First Name: Steve
Default Routing Cocobolo
Currently, I am using some 1/4" cocobolo for a small clock I am making and I am having a rough time with some serious tear out. It would be safer, but more time-comsuming, to cut the pieces on the bandsaw and then sand to the final shape, but I am looking at the possibility of using templates and the router to increase production. I am using the straight angle (90 degrees to the wood fibers) flush trim bit with the templates. Would the shear angle bit work better? Any thoughts/suggestions? Much appreciated.
SteveSawDust is offline
post #2 of 10 (permalink) Old 03-18-2009, 05:30 PM
Hamlin's Avatar
First Name: Ken
Hi Steve,
I've seen a tip not long ago about using the bit "with" the grain. This way, you're not "lifting" the fibers to create tear-out. You may have to flip the piece over a few times.
Hope this helps.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 10 (permalink) Old 03-18-2009, 05:58 PM
Hi Steve
" Would the shear angle bit work better? " = yes, they cut the wood unlike the standard straight bit that chops the filbers off, think of like a drill bit..the angle cuts the wood cleaner, or to say it works like a chisel /hand plane on a skew angle the blade is over the fibers and keeping them in place when the blade cuts them off clean, and just like a plane a little bit at one time is best.
post #4 of 10 (permalink) Old 03-18-2009, 05:59 PM
Yes, a bit with angled blades will improve your cut. You should also use a backer block to prevent tear out.
post #5 of 10 (permalink) Old 03-18-2009, 07:55 PM
Ralph Barker's Avatar
First Name: Ralph
I've also seen suggestions to slightly moisten difficult woods, but haven't tried that myself.
- Ralph
Ralph Barker is offline
post #6 of 10 (permalink) Old 03-19-2009, 05:54 AM
Obviously I'm not the expert around here, but I have several spiral bits, upcut and downcut, in various sizes and I will say that they make some pretty nice clean cuts. And, as a couple of the guys point out, the logic of the angled cut rather than the straight shearing action would certainly indicate that would be the result. I use them whenever I can. Just in the last few days I've been using a 1/2" shank 1/2" solid carbide upcut and man it makes cuts with surfaces that are perfectly slick.
For what it's worth.
Birch is offline
post #7 of 10 (permalink) Old 03-19-2009, 07:44 PM Thread Starter
First Name: Steve
Yep, I"ve used the spiral bits myself and I do like the cuts they make. I was trying to avoid buying one with the bearing...oh well, guess I'll have to bite the bullet. Thanks for the reply.
post #8 of 10 (permalink) Old 03-19-2009, 08:23 PM
Hi Steve
Here's link to one at a good price with free shipping
Spiral Flush Trim Router Bit
http://www.mlcswoodworking.com/shops...ushtrim_anchor
post #9 of 10 (permalink) Old 03-20-2009, 04:24 AM Thread Starter
First Name: Steve
Thanks, Bob...free shipping is always a plus. (Or, a minus, depending on how you look at it)
post #10 of 10 (permalink) Old 03-20-2009, 06:14 PM Thread Starter
First Name: Steve
Default Shear cut bit
Just picked up one of the shear cut bits for the cocobolo. BIG difference in the results. Thanks for all of the suggestions/advice
A day without routing is a waste...
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Freehand routing Visteonguy General Routing 53 07-12-2013 04:33 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
Routing with Template Tom template tom Guide Bushings and Templates 82 04-14-2009 02:25 AM
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 02:18 PM
