Router bit speed control - Router Forums
 4Likes
  • 1 Post By Cherryville Chuck
  • 1 Post By tvman44
  • 2 Post By hawkeye10
post #1 of 6 (permalink) Old 04-04-2018, 05:56 PM Thread Starter
Default Router bit speed control
Hello, All!
I have finally finished my bench/workshop and have received my first set of bits for my new router. Problem is, I have a Dewalt 616 router with a speed of 24,500 RPM and bits that should be run at 12,000-13,000 RPM. Seeing that I'm using a pin router and I'm working on small items this creates a small problem. Namely, A 200 pound gorilla couldn't hold onto a part while feeding it into that thing. (Note, that I don't work with wood but rather with acetate so there is almost no load on the router)
So, are there suggestions on external router speed controllers?
Thank you all in advance.
Kevin
PS. if you ever find a better pin arm than the "Daisy", drop me a line. The slop in this thing is crazy.
KCount is offline
post #2 of 6 (permalink) Old 04-04-2018, 06:07 PM
I'm pretty sure Rockler sells them and I'm also sure there are other sources. Make sure it's rated for the load the router will put on it. They aren't supposed to be used with speed controllers and possibly soft start but the instructions for one should specify.
Are you using the correct bits for plastic? They should have an O shaped gullet in the cutter. Also a jig for holding the parts if possible might help.
Danman1957 likes this.
post #3 of 6 (permalink) Old 04-04-2018, 07:02 PM Thread Starter
Definitely using the correct bits for acetate. In February I went to France to take a course in eyeglass making. They in turn gave me the name and item numbers for the bits I was trained with.
Biggest concern is the equipment I was trained on is not available in the US.
I'll check out Rockler and see what they have.
Thank you.
Kevin
KCount is offline
post #4 of 6 (permalink) Old 04-04-2018, 08:44 PM
tvman44's Avatar
First Name: Bob
Harbor Freight has a pretty good one at a very decent price. I like mine.
Herb Stoops likes this.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #5 of 6 (permalink) Old 04-04-2018, 10:20 PM
hawkeye10's Avatar
First Name: Don
Originally Posted by KCount View Post
Hello, All!
Kevin
Kevin, you might like this pin arm from Lee Valley. I don't know anything about it but I do know Lee Valley sells quality products.
Veritas® Pin Router Arm - Lee Valley Tools
Herb Stoops and mjadams61 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 6 (permalink) Old 04-05-2018, 07:59 PM Thread Starter
Sadly they no longer produce the Veritas pin router arm.
KCount is offline
Router bit speed! hawkeye10 General Routing 5 05-02-2017 07:17 PM
Modulated speed router problem. seanburns General Routing 6 08-19-2013 09:20 AM
Router speed control woodtony General Routing 53 01-03-2011 12:06 PM
Router Speed Control Mounting BigJimAK General Routing 13 04-14-2010 10:21 PM
Old Glossary Terms Mark Site Help and Suggestions 0 10-14-2008 02:30 AM
