Freud FT1700VCEK - Router Forums
post #1 of 4 (permalink) Old 03-19-2009, 08:02 AM Thread Starter
Default Freud FT1700VCEK
what table are people using with this router. recently picked up this router and found that it is machined differently than the standard router tables. Any information will be greatly appreciated. thanks.
buckeye24 is offline
post #2 of 4 (permalink) Old 03-19-2009, 09:00 AM
First Name: Steven
I am making my own table out of a bathroom cabinet. I used a Harbor Freight plate. It was easy to get the router centered and holes drilled. So far so good.
Steven Dupree
Columbia, Missouri USA
“I have not failed 10,000 times, I have successfully found 10,000 ways that will not work.”—Thomas A. Edison
creeker46 is offline
post #3 of 4 (permalink) Old 03-19-2009, 05:42 PM
Jason, your router will work in most tables. You may need to drill holes in the mounting plate but this is easily done and described elsewhere on the forums.
post #4 of 4 (permalink) Old 03-19-2009, 11:11 PM
First Name: Dave
Jason,
I purchased the Rockler HPL table, fence, & plate for my Freud router (1702VCEK). You have to specify that you want Group B routers. I have been very pleased with the entire package, especially the plate. It is 1/4" aluminum and was drilled perfectly to fit the router. I was more interested in using the router right away in a table than in building a table. Some day, I am sure I will create my own, but for now, this has worked well for me.
Good luck!
huskerfields is offline
Freud Router stjimm General Routing 1 01-03-2009 11:04 AM
Freud FT1700VCE vs FT1700VCEK rayq General Routing 5 07-30-2008 09:47 PM
Freud FT1700VCEK Design Change? Nick n Scratched Table-mounted Routing 14 07-21-2007 02:13 AM
Freud FT1700VCEK reible General Routing 10 06-07-2006 10:09 AM
