6" Diameter Circle - Router Forums
post #1 of 9 (permalink) Old 03-21-2009, 09:16 PM Thread Starter
Default 6" Diameter Circle
I need to cut a reasonably accurate circular disk. I don't have a "fly cutter" or a bandsaw, so I was thinking that there should be some way to do this, perhaps with a jig, on the router table. Anyone have any ideas?
Jim
jimcrockett is offline
post #2 of 9 (permalink) Old 03-21-2009, 09:28 PM
HI Jim
Most routers come with a edge guide that you can use for a circle cutter,most have a hole on the end for a pin/screw or can make one like below.. that's very accurate........
Router Forums - View Single Post - Circle Jig
Router Forums - View Single Post - Router Lifts -
Jim
post #3 of 9 (permalink) Old 03-21-2009, 10:04 PM
Default Circle cutting jig
Jim
Jim there are some simple circle cutting jigs that can be produced in your own workshop where the circles can be cut with greater safety especially if the material you are going to cut is quite thick.
You can also make a jig from MDF and plunge rout the circle required with the use of your router and template guides.
Tom (Template Tom)
P.S. Sorry
Doak is offline
post #4 of 9 (permalink) Old 03-22-2009, 03:54 AM
derek willis's Avatar
First Name: Derek
Jim,
This has to be the simplest circle cutting jig anyone evr saw, a strip of mdf with a hole to take a guide bush, put a pin in 6" from the edge of your cutter and fix, turn your router and plunge slowly, there you have it.
Derek
derek willis is offline
post #5 of 9 (permalink) Old 03-22-2009, 08:45 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by derek willis View Post
Jim,
Even I can't disagree with that!
Harry
harrysin is offline
post #6 of 9 (permalink) Old 03-22-2009, 09:27 AM
First Name: Derek
Good god harry!!!!
Derek
post #7 of 9 (permalink) Old 03-23-2009, 09:36 AM
harrysin's Avatar
First Name: Harry
Why the surprise Derek, I'm always happy to give credit where credit is due, but when I consider that I have a better or simpler or cheaper way to carry out an operation I'm prepared to have my say, usually with photographs to make my point.
Harry
harrysin is offline
post #8 of 9 (permalink) Old 03-27-2009, 07:29 PM
First Name: Alan
An even simpler option I've used that does not require a bushing, is to drill a hole in the router subbase to fit over a pin you put in the workpiece at the circle's center. It's a good idea to stick the work down on scrap with double sided tape.
I said it was simpler, not better.
AlanWS is offline
post #9 of 9 (permalink) Old 03-27-2009, 10:15 PM
Country: New Zealand
First Name: Murray
Send a message via Skype™ to Lemuzz
Jim,
6 inch circle 3inch radius lol
"There's no such thing as a stupid question but they are the easiest to answer."
Lemuzz is offline
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
What diameter bit do you use to make cutouts? Skyglider Router Bits - Types and Usage 6 03-04-2009 11:14 PM
Routing large diameter circles phil brough General Routing 3 08-02-2008 11:35 PM
Quick Fixed-Base Circle Question bfrance101301 Jigs and Fixtures 15 07-10-2008 10:02 PM
Small diameter circles. NewMontanaWorkshop Portable Routing 11 10-05-2004 10:25 PM
