how to route a stopped slot - Router Forums
post #1 of 17 (permalink) Old 03-22-2009, 09:25 PM Thread Starter
Default how to route a stopped slot
What is the best way to route a stopped 'through' slot on a router table?
Say I have a 1x2" where I want to route a 1/4" slot starting 2 inches from the end.
I used a start and a stop block attached to the fence, but I was not comfortable having my hands so close the the bit (even when it was burried in the stock), but I couldn't think of any clamp setup that would work.
I'm sure there must be an easy and safe way to do this on a table
Jesper
jkristia is offline
post #2 of 17 (permalink) Old 03-22-2009, 09:45 PM
HI Jesper
This is a good job for the ski jig, but if you don't have one and don't want to take the time to make one, this is what I suggest you do..
Use wider stock and longer stock,, put the slot in place and rip the board to size and cut it off to the right size..
Put masking tape on the fence to get you a starting point and a stopping point and the rest of it is easy.. just drop and slot,, wood is cheap but your fingers are not..
You can use stop blocks on the fence, but if you are going to use longer stock your table may not be that wide ( long) use a push block but don't put your hand over the bit at any time,if the bit breaks free it's coming out the top of the board..or when you plunge it down it's coming out of the top side..
use the 6" golden rule,,never but your hand with in 6" of the bit..
Jesper
post #3 of 17 (permalink) Old 03-22-2009, 09:53 PM
dovetail_65's Avatar
First Name: Dovetail
Hi Bob
I think he was having trouble thinking of clamping and even with the skii you have used a cam clamp table in the past.
Can you post the "how to" on that cam table, it's pretty straightforward and I can guess your measurements pretty well, but for a newbie I think some plans may be helpful if you could do it. I bet this would clear up a lot of holding issues for this poster and many others. I am sure you posted it before somewhere, maybe a bump is in order.
I really have never needed one, but I may make one for an off site project based on yours and others I have seen here.
dovetail_65 is offline
post #4 of 17 (permalink) Old 03-22-2009, 10:02 PM
levon's Avatar
First Name: levon
hey Nick ,
couldnt he just use a flat board and the stick method to hold the workpiece, like harry uses?
but he still would need the ski jig right? im just asking for myself.
levon
levon is offline
post #5 of 17 (permalink) Old 03-22-2009, 10:03 PM
HI Nick
Here's a link that will show how to clamp the stock in place for the ski jig..
Router Forums - View Single Post - for Levon
Originally Posted by nickao65 View Post
Hi Bob
post #6 of 17 (permalink) Old 03-22-2009, 10:12 PM
I know that, I thought you could post on HOW to make that Cam Clamp Table.
post #7 of 17 (permalink) Old 03-22-2009, 10:22 PM
Hi Nick
The post below shows all , both type of Cam Clamp Tables..it's so simple no plans need,, it can be any size one wants to make it..
http://www.routerforums.com/portable...243-levon.html
post #8 of 17 (permalink) Old 03-23-2009, 01:24 AM
xplorx4's Avatar
First Name: Jerry
I will have to look more closely at that when I am not tired, and I have something to work on and with. Paint starts this week, primer coat, then trim calk and final paint!!
Lamentations 3:22-23
xplorx4 is offline
post #9 of 17 (permalink) Old 03-23-2009, 08:33 AM Thread Starter
thank you, that jig seems like a good idea if you have to make many slots, but for a single slot is seems like a lot of work. But the idea of the jig is deinitely useful and next time I will mak a simple jig with to sticks for the router to rest on, the edge guide and then use the plunge to cut the slot instead.
Thank
Jesper
jkristia is offline
post #10 of 17 (permalink) Old 03-23-2009, 09:23 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Thank
Jesper
I answered this same question from a member some time ago, for a one off, the method is quick, simple and very safe.
Harry
harrysin is offline
best way to route a frame style edging? sf_basilix General Routing 6 02-11-2010 06:30 AM
What to route first? dwcurry Table-mounted Routing 4 03-02-2009 08:11 PM
SLOT Cutters A T FEHR Router Bits - Types and Usage 8 01-26-2009 03:30 AM
Stopped dado help Birch Portable Routing 5 03-20-2007 11:27 PM
router bit meeting resistance cutting a slot??? matey Router Bits - Types and Usage 3 10-03-2005 05:30 AM
