Ryobi RRT1600 - Page 2 - Router Forums
 11Likes
post #11 of 60 (permalink) Old 06-04-2018, 05:03 PM
First Name: Reuel
Default Ryobi RRT1600 exploded parts view
Ryobi RRT1600 exploded parts view document attached
Springs easy to remove.
Cheap router lift available
Template guide 68mm like Markita.
Just need an adapter ring to use Porter Cable type template Guide Bush (us: Guide Bushings)
Good 1st Router - with variable speed and 1/2" collet
It is easy to make a table top lift with ANY plunge router.
In fact if you get a cheap ALU plate AUD$73 it comes with a DIY Tabletop router lift kit for you too.
https://www.ebay.com.au/itm/Aluminum...oAAOSwSFJagV8K
Plastic insert shown already accepts 1 3/8" type Porter cable Guide Bushings - I know as I have one.
NO NEED OF a TRITON OR BOSCH just to get a tabletop lift.
Name:	al plate.jpg
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #12 of 60 (permalink) Old 06-05-2018, 10:12 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
As you probably have realised by now, for table mounting the springs must be removed. I've no hands on experience with this very nice router but I would think that removing the fine adjustment knob, it will take many turns, will allow the body to lift off the base with the springs sticking out ready to remove. It is most important to remember that the springs MUST be replaced if you ever want to use it hand held where it should perform perfectly, having reasonable power, variable speed, soft start and a multi-step turret.
MT Stringer likes this.
Harry
harrysin is offline
post #13 of 60 (permalink) Old 06-05-2018, 12:46 PM
My plunges have a brass plug that goes between the column lock lever and the plunge tube. If yours has one it can fall out when you remove the base. Make that side is down so it doesn’t happen.
post #14 of 60 (permalink) Old 06-05-2018, 01:43 PM
First Name: Reuel
Hi Harry
"MUST" is too strong a word.
As Philip suggested earlier there is a cheap heavy duty router lift available (AUD35) for plunge routers.
If one use such a lift, IMHO it won't be necessary to remove the springs.
I once remove the springs of my router then decided to put them back even though I only have a screw type lift.
Best Regards
Reuel
reuelt is offline
post #15 of 60 (permalink) Old 06-05-2018, 02:41 PM
MT Stringer's Avatar
Originally Posted by reuelt View Post
Hi Harry
That's funny. I made one once to help "lift" a router that was hard wired into a Harbor Freight table. Yep, it was a plunge type router and miserable to adjust. So, I got a scissor jack and placed it under the router. Worked as well as could be expected.
Name:	Lift Setup.jpg
Name:	2012-03-28 14.22.37.jpg
Name:	2012-03-28 12.43.53.jpg
Name:	2012-03-28 12.59.27.jpg
harrysin and reuelt like this.
MT Stringer is online now
post #16 of 60 (permalink) Old 06-05-2018, 04:41 PM
First Name: Reuel
Default DIY lift
When you buy a AU insert plate (see my earlier post) it comes with a DIY lift kit (see attached).
For many plunge router such as my Hitachi M12V it is very easy implement. Just replace the side threaded rod that holds the base to the router motor with this long bolt provided. You just need to drill a hole on the base plate and a bigger hole on the sub base and the AL insert
The T-allen key provided allows lifting the router from on top of the table. If you know the TPI you can adjust the height by counting the number of turns or quarter turns of the T-allen key. If you think that is too slow, just fix a hex bit to your cordless drill so that you can move your plunge router up and down more quickly depending on the speed of the drill.
THERE is NO NEED to remove the springs then.
Removing the springs may even be bad if you are using spiral bits as the router may creep upwards or vibrate when there are no springs to hold it down.
BUT since the RYOBI RRT1600 has a 4 year replacement warranty, it is best to just buy and use the scissors lift & don't remove the springs to avoid voiding the warranty.
Best Regards
Reuel
reuelt is offline
post #17 of 60 (permalink) Old 06-06-2018, 09:04 AM
harrysin's Avatar
First Name: Harry
I think you might have miss-read what I wrote......"It is most important to remember that the springs MUST be replaced if you ever want to use it hand held where it should perform perfectly"
"If you ever want to use it HANDHELD"
Harry
harrysin is offline
post #18 of 60 (permalink) Old 06-06-2018, 07:48 PM
My router plate is only held in by gravity so using a scissor lift without removing the springs wouldn’t work very well. Fortunately my M12V2 has above table adjustment capability.
post #19 of 60 (permalink) Old 06-07-2018, 07:55 AM
harrysin's Avatar
First Name: Harry
Some years ago I was busy with a number of projects and happened to be in our local recycling depot when I saw a table top router table which I bought for $3.00! I then went to our local pawn shop, The Cash Converters, and bought a Ryobi router which I modified for above table height adjustment. Here are a few shots taken during the conversion. This conversion idea could probably be used on many different routers.
reuelt, MT Stringer and Hypnotoad like this.
Harry
harrysin is offline
post #20 of 60 (permalink) Old 06-07-2018, 10:09 AM
I guess Zippy got his answer and moved on. Sad because there is a lot of good info in this thread.
Newbie question : Makita M3600G vs Ryobi RRT1600-S - which one would be better? DiverDoug General Routing 22 01-10-2019 08:50 AM
RYOBI vs SKIL Benchtop Drill Presses BRAVOGOLFTANGO Tools and Woodworking 12 10-22-2012 09:37 AM
Ryobi Router recall BJBennett General Routing 3 04-16-2012 06:09 PM
Ryobi Straight Edge Guide doesn't fit Ryobi RE180PL1 Router BabyGerald General Routing 1 09-16-2011 07:31 PM
New router use w/ Ryobi 1801M1 router 1/4 inch collet RexM Router Bits - Types and Usage 1 04-11-2011 04:37 PM
