Leveling setscrews move - Router Forums
post #1 of 11 (permalink) Old 04-01-2009, 03:46 PM Thread Starter
Default Leveling setscrews move
I have a shop made router plate in my saw mounted router table. It is 3/8" polycarbonate with 6 leveling screws. Vibration from various bits will occasionally cause one or more of the setscrews to back out or extend, resulting in a plate that is not level with the top.
What can I use to tighten the fit between the tapped hole in the plate and the set screws? I have considered Locktite, but don't know if it eats polycarbonite??????
Roy Bennett is offline
post #2 of 11 (permalink) Old 04-01-2009, 03:56 PM
Ghidrah's Avatar
First Name: Ronald
You can slick them with paint or primer too!
Ghidrah is offline
post #3 of 11 (permalink) Old 04-01-2009, 06:04 PM
kolias's Avatar
First Name: Nicolas
I doubt it that Locktite will harm the plate. Try a drop somewhere on the plate.
Nicolas
kolias is offline
post #4 of 11 (permalink) Old 04-01-2009, 06:20 PM
Ralph Barker's Avatar
First Name: Ralph
Another option would be to use longer set screws, and put a lock nut on the underside.
- Ralph
Ralph Barker is offline
post #5 of 11 (permalink) Old 04-01-2009, 06:41 PM
moreorles2000's Avatar
First Name: les
ditto on the longer screws & use a wing nut & lock washer. that way you dont need a wrench to adjust them. i use the toilet mounting bolts.
moreorles2000 is offline
post #6 of 11 (permalink) Old 04-01-2009, 06:48 PM
Just one more way
Pull out your ball peen hammer and deform the threads just a little bit (almost a flat spot)..no glue needed this will make them shelf locking so to speak..
If you have good eyes and are good with your drill press you can drill a small hole in the set screw and put a nylon screw in the hole and then cut off the nylon screw and you just made a locking type set screw, I have done that many.many times..
post #7 of 11 (permalink) Old 04-01-2009, 10:53 PM
First Name: Frank
You could wrap the threads with a thin layer of the teflon plumbing tape or use a dab of rubber cement kid's glue.
Dr Frank is offline
post #8 of 11 (permalink) Old 04-02-2009, 12:25 AM
Country: New Zealand
First Name: Murray
Send a message via Skype™ to Lemuzz
Use Loctite Screwloc. Easily removed with a screwdriver but won't vibrate loose
"There's no such thing as a stupid question but they are the easiest to answer."
Lemuzz is offline
post #9 of 11 (permalink) Old 04-02-2009, 08:11 AM
Fourleftpaws's Avatar
First Name: Larry
Send a message via Yahoo to Fourleftpaws
Try some of your wife's (if your married - other wise visit a drug store) clear finger nail polish. It will break loose when needed and if you want to remove it totally - use some finger nail polish remover. I have used this method for years on screws that hold scopes on rifles - and I am sure the recoil of a rifle is more than the vibration of a router.
Larry
"Have you hugged your pet today"
Fourleftpaws is offline
post #10 of 11 (permalink) Old 04-02-2009, 01:39 PM
It seems like once a year or so I have to repost about a product that I have found indispensable. The product is called Vibra-tite. You apply it to threads, let it dry for about 20 minutes and then assemble. The really neat thing about this product is that you can always make adjustments and after 24 hours it resets to lock in place. It is made by ND industries (formerly Nyloc Detroit) and sold world wide.(Yes Harry, even in Oz) I checked with a sales rep and it is safe to use on acrylic, phenolic and all metals.
Stupid move on my part Glenmore Lobby 29 10-29-2008 05:44 AM
