Guide Pins - Router Forums
post #1 of 4 (permalink) Old 04-02-2009, 12:30 PM Thread Starter
Default Guide Pins
Where can I order guide pins for my table? - I lost mine and no one seems to carry them.
Publican is offline
post #2 of 4 (permalink) Old 04-02-2009, 01:17 PM
Oak Park sells guide pins singly or in 3 packs.
post #3 of 4 (permalink) Old 04-06-2009, 04:51 PM
dutchman 46's Avatar
First Name: Howard
Hello Ken, Welcome to the Router Forum. Glad that you got the answer for the pins. I usually make mine, but thats because i have the stock to do it myself.
John 3:16
dutchman 46 is offline
post #4 of 4 (permalink) Old 04-06-2009, 05:05 PM
Hi Ken
You can make one in about 2 mins.or less, stop by the hardware store and pickup a brass bolt,cut off the head and almost all the threads and you have one,, some are push in type and some are thread in type..
If you have the push in type just cut off the head,and the threads then chuck it up in your battery drill and grind it down just a little to pop in the hole,the norm is a 3/16" diam. on the push in type...
Below you will see just of some of the ones I have made but just a simple brass both will do just fine
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 08:25 PM
Makita RF1100, 1101, RD1100, 1101 Straight Guide markus General Routing 4 01-20-2009 11:46 AM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Porter-Cable template guide no where to be found jnam Portable Routing 5 07-21-2006 07:54 PM
The use of template guides (Guide bushes) template tom Portable Routing 28 12-04-2004 08:18 PM
