Oh, that edge - Router Forums
 11Likes
  • 1 Post By rrrun
  • 1 Post By difalkner
  • 4 Post By Cherryville Chuck
  • 1 Post By reuelt
  • 2 Post By MEBCWD
  • 1 Post By rrrun
  • 1 Post By CharleyL
post #1 of 10 (permalink) Old 06-11-2018, 05:03 PM Thread Starter
rrrun's Avatar
First Name: Henry
Default Oh, that edge
I was asked to refinish a cutting board that the client uses ... and I'm in love with the shape. The edges are shaped almost like the leading edge of an airplane wing, or a bullet shape ... and the interior hole has the same rounding.
Piece is 3/4" thick, and the edge are just slightly curved ... it's 6-7/8" wide at the center, and 6-5/8" wide at each end. Same slight curve on each end; this piece is not square. And, I'm in love. I must do this.
Can't find the router bit to do the edge treatment. This is done with a router, yes?
Here are the pix of the piece as I was resurfacing it. And, as a bonus, here's the website where you can buy one for $125: here.
TenGees likes this.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #2 of 10 (permalink) Old 06-11-2018, 05:25 PM
Gene Howe's Avatar
First Name: Gene
Looks like it could be done in two passes, on a router table, with a round over bit with a radius some what larger than the board thickness. 1/2 the bit's radius would be used on each pass.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 10 (permalink) Old 06-11-2018, 07:27 PM
First Name: Orlando
That profile could have been cut on a band saw then sanded down or done on a CNC machine since it's probably a production run piece. I've never seen a router bit with that profile on it unless they have it specially made for them.
OBG65 is offline
post #4 of 10 (permalink) Old 06-11-2018, 07:48 PM
difalkner's Avatar
First Name: David
I would cut the edge on the table saw like I do the B-52 Walnut trophies that I make -
https://youtu.be/ZQV-C-DNRr4?t=30s
The rest of the edge I do with a router. The hole is a bit more of a challenge, though.
David
MEBCWD likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #5 of 10 (permalink) Old 06-11-2018, 08:30 PM Thread Starter
rrrun's Avatar
First Name: Henry
David
Exactly. This is a machined piece; the curve is oh so perfect in your hands. It has to be done with a guide bearing and then hand smoothed ... or perhaps it's done with a jig so you can hold the curve as you go the length of the piece? I'm sure some smart person here will tell me what I should already know!
Henry
Santa Clarita, CA
rrrun is offline
post #6 of 10 (permalink) Old 06-12-2018, 01:25 AM
The curve might be a table edge profile. Kind of like this one but there are quite a few variations. https://www.whitesiderouterbits.com/products/3294
CharleyL, MEBCWD, TenGees and 1 others like this.
post #7 of 10 (permalink) Old 06-12-2018, 03:38 AM
First Name: Reuel
Cutting Boards Edward Wohl Woodworking & Design
Individually hand sanded.
difalkner likes this.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #8 of 10 (permalink) Old 06-12-2018, 08:59 AM
MEBCWD's Avatar
If I were mass producing these I'd use my shaper, for a few the thumbnail bit would be my choice. Roundover bit for the hole.
DesertRatTom and Herb Stoops like this.
MEBCWD is offline
post #9 of 10 (permalink) Old 06-12-2018, 09:33 AM Thread Starter
rrrun's Avatar
First Name: Henry
I am pretty sure this is the ticket. The drilled hole rounding matches the rounding on the edge, and the gentle curve that extends over about 5/8" is oh so elegant in the hand. Can't wait to do this!
Simply could not find this on my own when I was looking. Thanks much for the assist!
Cherryville Chuck likes this.
Henry
Santa Clarita, CA
rrrun is offline
post #10 of 10 (permalink) Old 06-12-2018, 10:02 AM
CharleyL's Avatar
First Name: Charley
A thumbnail bit should be able to do it, but it will require careful height adjustment and two passes, one on each side. You won't be using the full cutting surface of the bit. Use a fence with zero clearance around the bit too.
Charley
rrrun likes this.
Central North Carolina
CharleyL is offline
Modifying Bosch RA1054 edge guide AshleyJ Jigs and Fixtures 9 01-24-2018 01:17 AM
No Drip Edge On A Radiused Counter Top Edge JIMMIEM Tools and Woodworking 3 03-19-2017 02:25 PM
Scraper burnisher? hawkeye10 Tools and Woodworking 42 02-12-2017 07:58 PM
Greater than japa62 Jigs and Fixtures 12 01-16-2013 12:03 AM
Jig for Edge Drawer Pull Inlays Troy_Utah Jigs and Fixtures 9 01-30-2010 07:05 AM
