Base plate - Router Forums
post #1 of 3 (permalink) Old 06-16-2018, 07:47 AM Thread Starter
Default Base plate
What is the benefit of an insert vs a base plate mount?
Sawdust74 is offline
post #2 of 3 (permalink) Old 06-16-2018, 09:57 AM
Gene Howe's Avatar
First Name: Gene
Depends on the insert and router attachment design. Mine's a Jessem and the router is clamped within the lift. It's far sturdier than a plate alone.
If you're not contemplating a lift and, have a smaller router, using the router plate would be fine. Probably be easier to change bits, too.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 3 (permalink) Old 06-16-2018, 03:18 PM
First Name: Reuel
Originally, the insert was proposed because routers have handles so it was wider that the baseplate (especially plunge routers) and so it was not possible to take out the router from the top to change bits if base plate mounted unless the baseplate is replaced with a larger diameter and thinker base plate.
The hole of the baseplate is large for bigger diameter bits to pass though. With a router table insert, it is possible to reduce or enlarge the hole with plastic sub-inserts depending on the bits used.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
How Wide Is Your Home Plate Frankj3 Lobby 13 09-06-2016 04:16 PM
longer base plate screws for Bosch 1617 Stefftech New Member Introductions 9 04-07-2015 07:02 PM
Triton MOF001 Base plate Issues. fleetinglyshort General Routing 6 10-24-2014 06:04 AM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
