Triton TRA001 High pitch noise - Router Forums
 11Likes
  • 4 Post By Hypnotoad
  • 3 Post By Cherryville Chuck
  • 2 Post By DesertRatTom
  • 2 Post By Bob Adams
post #1 of 10 (permalink) Old 06-26-2018, 05:40 PM Thread Starter
Default Triton TRA001 High pitch noise
I just mounted my new Triton into a router table. It does a great routing, but all the time it’s running there’s a high pitch noise in the background. It’s louder a faster speeds. It doesn’t sound like scraping metal, and doesn’t seem to overheat. It’s just annoying, and forced me to use hearing protection. Anyone have the same experience? Any ideas?
emnesto is offline
post #2 of 10 (permalink) Old 06-26-2018, 05:55 PM
Hypnotoad's Avatar
First Name: Phillip
You should always wear hearing protection, as it's not only the loudness of the sound it's the length of time you're exposed to it that does damage. I used an Elu router once that did this for years, others that own this router will probably chime in with there experience. But keep that hearing protection on.
Tight fisted old so-and-so!
Hypnotoad is offline
post #3 of 10 (permalink) Old 06-26-2018, 07:22 PM
I don't start up any power tool until my ear muffs go on. I'm already partially deaf so I don't want to lose what's left. Those high pitched whines are particularly hard on your hearing. Unless it keeps changing pitch I don't know if I would be concerned. If it's the same noise every time you use it then it's normal. It could be a bearing whine that might mean it will fail sooner than it should but it could also be fan noise too.
harrysin, Danman1957 and jj777746 like this.
post #4 of 10 (permalink) Old 06-26-2018, 08:32 PM
I also wear hearaing protection at all times. Have lost a lot of my high frequency hearing range, starting with a Beach Boy's concert 45 years ago. As to the noise, I'd contact TritonTools.com customer service. https://www.tritontools.com/en-US/Support. Describe the noise, particularly if it changes when you slow down the router. I have never really heard my triton do that, but then I've got some really effective ear protection, and I don't wear my hearing aids under them, so high pitch sounds are hard to hear for me.
harrysin and jj777746 like this.
post #5 of 10 (permalink) Old 06-26-2018, 08:37 PM
Bob Adams's Avatar
First Name: Bob
I agree with the hearing protection, but to your question, does the noise occur with all bits? It might be the bit shape causing the noise,
harrysin and Roy Drake like this.
Bob Adams is online now
post #6 of 10 (permalink) Old 06-26-2018, 09:04 PM
kp91's Avatar
First Name: Doug
Originally Posted by emnesto View Post
I just mounted my new Triton into a router table. It does a great routing, but all the time itís running thereís a high pitch noise in the background. Itís louder a faster speeds. It doesnít sound like scraping metal, and doesnít seem to overheat. Itís just annoying, and forced me to use hearing protection. Anyone have the same experience? Any ideas?
could be the cooling fan, may have to do with how air flows while mounted in your table.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #7 of 10 (permalink) Old 06-26-2018, 11:12 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #8 of 10 (permalink) Old 06-27-2018, 01:13 AM
Can you mount something on the inside of the router table box, to dampen the sound? (sheet lead)
Rick's pretty interested in this stuff, from his audio install days.
Some other members as well if I'm not mistaken.
DaninVan is offline
post #9 of 10 (permalink) Old 06-27-2018, 10:00 AM
First Name: Gary
Most people don't notice that bearings get noisier over time. I worked in equipment rentals for 42 years. In that time I noticed this sound difference in many tools just prior to bearing failure. It was common in Bosch belt sanders...and when the bearings would finally seize, it would melt the body (plastic) of the tool and it would have to be scrapped. I learned to tune in to the sound of bearings from that. Tools subjected to fine wood dust seem to be most effected.
gmercer_48083 is offline
post #10 of 10 (permalink) Old 06-27-2018, 10:36 AM
Forgot to say welcome. I want to add, blow the router out with compressed air. See if that chanes the sound.
GIVEAWAY: Triton Dual Mode Precision Plunge Router TRA001 Cricket Featured Topics 224 04-10-2017 08:32 PM
Triton (TRA001) Router Troubles 1Montanasky1 Table-mounted Routing 7 01-22-2016 05:44 PM
My new Triton TRA001 pete4242 Table-mounted Routing 25 07-04-2015 03:19 AM
Triton TRA001 and the M-Power CRB7 - Will they work together? marc82much General Routing 5 02-05-2015 07:42 AM
triton TRA001 and table paul-c Table-mounted Routing 18 10-06-2014 06:56 AM
