T-Track and other table questions - Router Forums
 32Likes
post #1 of 23 (permalink) Old 07-13-2018, 10:15 PM Thread Starter
username1's Avatar
First Name: Art
Default T-Track and other table questions
I recently built myself a Router table - around 30"x36". Made it out of work Table my Father built a long time ago. (Will post pics soon).
Will be keeping it simple, and using clamps for the fence, similar to the Oak Park design. Unless there is a better reason to mount the fence another way...?
However it seems like a T-Track might be handy to have parallel to the fence. Do you agree? If so, what are the benefits? And how far would you mount it from the fence area (and why)?
Thank you!
"You kids get offa my lawn!"
username1 is offline
post #2 of 23 (permalink) Old 07-13-2018, 11:25 PM
kp91's Avatar
First Name: Doug
Art, I have no tracks or slots in my table, and it's worked well that way for over 2 decades.
The problem with slots or T-track in my opinion is how far they have to be away from the bit due to the router insert plate. Of course, many have installed tracks and love them. I also worry that in a shop that has wide humidity swings the table might not stay flat with grooves put in it.
My advice is to try it without grooves first, you can always add them later
Rogerdodge and Herb Stoops like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 23 (permalink) Old 07-14-2018, 12:52 AM
Unless you have figured out a way to keep the fence parallel to the t-track then it's useless as far as using it for jigs. For example a miter sled or push block works better for doing the ends of rails or half lapping, etc. some do like it for attaching a feather board though but you can also make the feather board longer and clamp it to the edge instead. I put the t-track across in one of my tables to see if I liked it and wound up never using it. I also had t-tracks in that table for clamping the fence down. I went back to clamps on the newest one like yours but that is about a 50/50 deal. Either way is pretty good. I really couldn't find an advantage from one to the other.
BTW, one other option for mitering, half lapping, or doing rail ends is to make a sliding fence that rides along the edge of your table. The 90* arm on mine just misses the bit. You can drill a hole in the arm and attach an F clamp in it to hold your work if you want. If you are interested I'll either go through my uploads and find the picture or go take another one of it.
post #4 of 23 (permalink) Old 07-14-2018, 07:21 AM
mjadams61's Avatar
First Name: Marlin
I would be
mjadams61 is offline
post #5 of 23 (permalink) Old 07-14-2018, 09:01 AM
Gene Howe's Avatar
First Name: Gene
No t track in my table. No need. There are dozens of ways to mount feather boards to the table without out a track. And, as Chuck mentioned, several methods to guide long work for end cuts.
You'd be better served with a t track mounted on the fence, either on the top or the face...or both. Lots more utility than in the table.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #6 of 23 (permalink) Old 07-14-2018, 09:16 AM
First Name: Gary
Art, My portable router in a box (similar to Oak Park) uses a fence held down at one of the table with a pivot bolt, which allows me to swing the fence for adjusting closer and farther from the bit. I use a clamp to hold it to the table top once adjusted. By swinging the fence at one end I can sneak up for precise cuts. It works very well for me, and have found no draw backs. My router in a box has a 2"x 2" attached to the bottom which is clamped in my bench vice, or can be used on my workmate.
gmercer_48083 is offline
post #7 of 23 (permalink) Old 07-14-2018, 09:30 AM
Contributor of the Month
I would like to see a picture of the sliding fence, if it's not too much trouble. Thank You
JIMMIEM is offline
post #8 of 23 (permalink) Old 07-14-2018, 10:11 AM
I have a Rockler table with the T track running across the front. I've never used it. What I'd really like is a T track on a tall fence, but clamping feather boards works fine. If you install a T track, I suggest you add an additional layer to the underside of the table, or use trusses to keep the thing flat, particularly if you have a higher power machine under the table.
JFPNCM and Barry747 like this.
post #9 of 23 (permalink) Old 07-14-2018, 10:18 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I got tracks all over my table
Bob Cooper's Woodwork Projects Photo Gallery by John Cooper at pbase.com
The first one is a mitre fence sliding track. The next one is a T track for clamping end blocks (I do a lot of small blind end grooves).
The two short ones are for micrometer adjustable fence clamps.
There are 2 x T tracks on the fence, one on top and one along the top front edge also used for end stops and backing boards.
Do I "NEED" them? doubtful.
Do I "USE" them? yes, a lot.
You decide what youre going to do with the table, that will decide what you need on it.
sunnybob is online now
post #10 of 23 (permalink) Old 07-14-2018, 10:23 AM
TenGees's Avatar
First Name: Paul
I used clamps to hold my fence for years but I recently added simple locks and they are very convenient. See: https://www.routerforums.com/project...ml#post1934490 for the basic idea. If your fence is longer than your table it's very easy to add.
Herb Stoops likes this.
TenGees is offline
Track Saws Steven Owen Tools and Woodworking 174 10-13-2017 11:18 PM
Triton plunge, track saw review DesertRatTom Tool Reviews 11 09-29-2017 09:38 AM
T Track vs T Slot Router Bit Selwyn Senior Router Bits - Types and Usage 3 02-23-2014 08:29 PM
Rookie here, got a question wyatt earp New Member Introductions 6 07-18-2008 08:33 AM
