Not sure - Router Forums
 18Likes
post #1 of 12 (permalink) Old 07-22-2018, 03:53 PM Thread Starter
First Name: Doc
Default Not sure
I'm building a Humidor and want to round over all 8 edges. My question is should I do the top first and then the corners or do the corners first?
doc8254 is offline
post #2 of 12 (permalink) Old 07-22-2018, 04:10 PM
Gene Howe's Avatar
First Name: Gene
Corners first. It's the law.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 12 (permalink) Old 07-23-2018, 07:45 AM
First Name: Art
Do the grain that will rip out first then clean up the ripped out part with the pass going with the grain.
harrysin, JFPNCM and doc8254 like this.
mgmine is offline
post #4 of 12 (permalink) Old 07-23-2018, 09:00 AM
First Name: Gary
Generally; To prevent tear out, try to take incremental cuts to sneak up on the final depth, routing the end grain first, and if possible use a backer board at the end of the cut. Route counterclockwise if hand routing, or from left to right if using a router table.
doc8254 likes this.
gmercer_48083 is offline
post #5 of 12 (permalink) Old 07-23-2018, 09:57 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
As stated, end grain first followed with the grain, using this method I've never had breakout.
Harry
harrysin is offline
post #6 of 12 (permalink) Old 07-23-2018, 04:41 PM Thread Starter
First Name: Doc
I took your advise and the corners came out perfect! Thanks!!!
kp91 likes this.
doc8254 is offline
post #7 of 12 (permalink) Old 07-23-2018, 04:43 PM Thread Starter
First Name: Doc
Done! Looks great with no tear out! Thanks!
Rogerdodge likes this.
doc8254 is offline
post #8 of 12 (permalink) Old 07-24-2018, 06:32 AM Thread Starter
First Name: Doc
Beautiful work!
doc8254 is offline
post #9 of 12 (permalink) Old 08-05-2018, 08:54 AM
pusserboy's Avatar
First Name: Stuart
Turned out very beautiful, how did you indent under the cover and what kind of wood is it made of.
Stuart
pusserboy is offline
post #10 of 12 (permalink) Old 08-05-2018, 09:28 AM
harrysin's Avatar
First Name: Harry
I'm assuming that you meant the ring box, if so here is a pdf showing how I made it.
rjtwin501 and jj777746 like this.
Harry
harrysin is offline
