Router Forums (https://www.routerforums.com/forum.php)
-   Table-mounted Routing (https://www.routerforums.com/table-mounted-routing/)
-   -   Table and fence position (https://www.routerforums.com/table-mounted-routing/135849-table-fence-position.html)
ranman 08-25-2018 01:11 PM
1 Attachment(s)
I don't see this configuration used anywhere. Why not?
mimac 08-25-2018 01:18 PM
Not only that I don't see anything:grin:
ranman 08-25-2018 01:29 PM
That's why I asked. :D
Stick486 08-25-2018 01:48 PM
think it through and you'll come to the correct conclusion...
CharlesWebster 08-25-2018 01:48 PM
Because that would be cutting with the back side of the cutter. The cutter turns clockwise, you should be feeding the material across the right side of the cutter not the left.
ranman 08-25-2018 01:58 PM
1 Attachment(s)
The router is in a table. Unless I have a Chinese router this ought to be running the correct direction....into the work piece.
ranman 08-25-2018 02:34 PM
I'm truing up a section of some old Wilsonart flooring so I can inset some repair pieces using lap joints in the floor and repair piece. I need flawlessly parallel pieces. I did a test repair and this setup works like a dream.
Hardest part will be making the cutout in the floor perfectly square.
I glued a teplate to the floor using hot glue. Then I used a 1/4" bit the full depth og the material to make the first cut, then changed my bit to 3/4" to make the lap joint. The repair's corners will be rounded in the floor of course, but I found that with some sandpaper on a block of wood, hand shaping the corners in the repair piece isn't all that hard to do. An $800 repair will save the homeowner from replacing a $9000+ floor.
DaninVan 08-25-2018 02:42 PM
I thought you wern't supposed to trap a work-piece between the fence and the bit?
DaninVan 08-25-2018 02:58 PM
OK...here's the relevant info!
Yup; don't trap your work-piece!
http://go.rockler.com/tech/47905-ProFence-Inst.pdf
Stick486 08-25-2018 03:25 PM
you are not...
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
