I need help- craftsman table 320.37599 - Router Forums
 4Likes
  • 3 Post By Stick486
  • 1 Post By Stick486
post #1 of 8 (permalink) Old 11-22-2018, 07:19 PM Thread Starter
First Name: Kevin
Default I need help- craftsman table 320.37599
I bought a craftsman table 320.37599 and I have a older craftsman router 315.175040 but the holes don’t match up, will they work together
Kaustin6 is offline
post #2 of 8 (permalink) Old 11-22-2018, 08:18 PM
Why not...
work w/ just the base's plastic sub-plate, tape it down, then transfer punch the required new holes and bore new ones..
careful positioning is important ya know...
when you mount the base onto the table, leave the sub-base off...
remember not to orientate the sub-base in mirror image...
it's easy to do...
you should be looking at the bottom od the base plate as it lies on top of the table...
Jack Wilson, TenGees and hawkeye10 like this.
post #3 of 8 (permalink) Old 11-22-2018, 08:34 PM
hawkeye10's Avatar
First Name: Don
A little work and you will have a nice router table.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 8 (permalink) Old 11-22-2018, 10:29 PM
Sears put out some stamped metal tables and they were router specific as the metal was countersunk so the mounting screws would be flush. Your router might fit one of those type tables as they were likely made by Ryobi and your model router was also made by Ryobi (315. serial numbers). If this one is a composite top then you can do what Stick said. You'll need a countersink drill bit to countersink the holes you drill so that they are flush or below the top surface.
post #5 of 8 (permalink) Old 12-03-2018, 02:45 AM Thread Starter
First Name: Kevin
ok I got the router to fit (had to purchase new screws) when lower/raise the router but it seems not able to raise it any higher,
does the bit need to go all the way in, if it stay out a little maybe the bit will be higher. or do I need to replace the router with a different model ( the model I have is not on the list of models that will fit.
Kaustin6 is offline
post #6 of 8 (permalink) Old 10-08-2019, 06:34 PM
Kaustin6 -- Where did you purchase the screws from?
Slim6/4 is offline
post #7 of 8 (permalink) Old 10-08-2019, 08:59 PM
Hi Slim and welcome. I’m not sure if the 315 model had metric screws but that model prefix means made by Ryobi so it’s a good chance. I don’t know about the US Home Depot stores but the ones in Canada sell metric screws. Take one of your old ones with you to match size and thread pitch.
post #8 of 8 (permalink) Old 10-08-2019, 09:12 PM
Lowes carries metric..
as well as Ace...
Cherryville Chuck likes this.
Add a jig saw table to your table saw pbriggs8 Project Plans and How To 11 06-14-2016 09:16 PM
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Craftsman 02768 for router table use? VtGeezer Table-mounted Routing 1 10-25-2014 11:33 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Craftsman Router & Bosch Table camelracer Table-mounted Routing 13 01-19-2009 07:32 PM
