Router speed controllers - Router Forums
 15Likes
post #1 of 20 (permalink) Old 11-23-2018, 10:57 AM Thread Starter
First Name: Marc
Default Router speed controllers
Has anyone used a speed controller and if so, is it helpful? Thanks for any wisdom as I am not very experienced with routing.
K4ZMB is offline
post #2 of 20 (permalink) Old 11-23-2018, 12:53 PM
I don't have one but lots of members have. You can't use them is you already have one built in. If you get one make sure the amp rating is equal to or greater than what you intend to plug into it.
post #3 of 20 (permalink) Old 11-23-2018, 02:37 PM
JOAT's Avatar
First Name: Theo
Don't have one, never tried one, for what I do and how I do it, never felt any need for one. If you can, I'd try one before buying, no sense in spending money without trying one first, and you may not like it.
neville9999 likes this.
JOAT is online now
post #4 of 20 (permalink) Old 11-23-2018, 03:12 PM
Hypnotoad's Avatar
First Name: Phillip
I made one using one of those cheap modules off Ebay to use with my 500 watt AEG drill in a drill stand, It works a treat, prior to this if I wanted to drill any hole bigger than 1/8" in metal the drill bit would dance all over the place. I can slow the drill down to around 20% with it, but bear in mind that they do reduce the amount of power as well, so your router will slow down but also have less torque as well. The ones from Harbor Freight etc would use the same or similar circuitry.
I got this one and put it in a case (only do this if you are competent with working with mains voltages, you could electrocute yourself), it says it's rated to 2000w but I wouldn't use it for anything over half that, those pesky Chinese do fudge the figures a lot.
And as stated in other posts you can't use them with routers that have soft start, speed control or with induction motors.
graeme.c.payne likes this.
Tight fisted old so-and-so!
Hypnotoad is offline
post #5 of 20 (permalink) Old 11-24-2018, 09:35 AM
First Name: Art
I used one on my Hitachi MV12 router that the speed control had burned out. They work fine but you do notice a loss of torque at some speeds. I got mine at Harbor Freight for a lot less than the ones advertised in the catalogs.
mgmine is offline
post #6 of 20 (permalink) Old 11-24-2018, 10:22 AM
I use one on both my router tables, wouldn't be without them.
The one is on a Bosch 1617 motor, and the other is on a PC 7518. I set the motor on high setting and plug it into the speed control. The reason I use them is they are easier to access in the router lifts than the speed controls on the motors themselves.
MoHawk likes this.
Herb Stoops is online now
post #7 of 20 (permalink) Old 11-24-2018, 02:26 PM
graeme.c.payne's Avatar
First Name: Graeme
As a second-round newbie (I've been substantially away from routers for several decades) I have a question about speed controls. It seems basic, but ...
I know that a fair number of router bits specify a maximum speed. So the question is, with an add-on router speed control,
How does one know what the current speed is?
I know there are several ways I could measure it in static, no-load conditions. (Build a simple optical or Hall-effect tachometer.) But what about real world in-use conditions?
Sent using Tapatalk while wondering what route to take
Graeme C. Payne
Middletown, Maryland, USA
I try to learn something new every day. Then I try to remember what it was!
graeme.c.payne is offline
post #8 of 20 (permalink) Old 11-24-2018, 02:34 PM
I go by the sound of the bit. I turn on the router with no load on the bit and dial it up til it sounds nice and smooth,no vibration, not screaming. The small diam. bits, will take the full speed, the larger bits will take a slower speed.
mgmine and graeme.c.payne like this.
post #9 of 20 (permalink) Old 11-26-2018, 08:08 AM
First Name: Art
As Herb said listen to the sound of the bit. About the only time I find it necessary to adjust the speed is when I'm using a very large paneling bit. If it sounds like a propeller then it's going too fast. Don't put too much stock into what is given as speed for different size bits. With very little practice it will become second nature.
mgmine is offline
post #10 of 20 (permalink) Old 11-26-2018, 10:49 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I've had a 1/2" makita router in my table for 4 years now. No speed control. never needed one so far. I've used bits up to 1 1/2" across with no problems.
I suspect 2" wide or more would definitely need speed control.
sunnybob is offline
Router Speed Control for PC 7519 UglySign General Routing 14 01-16-2017 12:12 AM
Need router speed control advice cpcustoms Tools and Woodworking 6 04-10-2015 08:43 AM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Modulated speed router problem. seanburns General Routing 6 08-19-2013 08:20 AM
