Extreme Router Table Build - Router Forums
 11Likes
  • 10 Post By Flipsaw
  • 1 Post By TWheels
post #1 of 8 (permalink) Old 12-04-2018, 09:42 PM Thread Starter
First Name: JJ
Default Extreme Router Table Build
This is an Izzy Swan build. Looks very interesting and useful.
Flipsaw is offline
post #2 of 8 (permalink) Old 12-05-2018, 07:25 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Nice. N
neville9999 is online now
post #3 of 8 (permalink) Old 12-05-2018, 11:52 AM
TenGees's Avatar
First Name: Paul
It sure adds a lot of profiles and versatility.
TenGees is offline
post #4 of 8 (permalink) Old 12-07-2018, 11:00 AM
TWheels's Avatar
As I write this post I have the link to this video (which I found independently of @Flipsaw ). I was about to start a new thread seeking opinions about this particular project and horizontal tables in general as opposed to using coping sleds that hold the workpiece at variable angles. Unfortunately I do not have anything more than a plan in my head.
@Flipsaw , thanks very much for starting this thread.
Flipsaw likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #5 of 8 (permalink) Old 12-12-2018, 12:11 PM
First Name: Doug
Thanks for the link, Flipsaw
I'm getting ready to start building a new router table & I may be able to use some of Izzy Swan's ideas.
dwall174 is offline
post #6 of 8 (permalink) Old 12-13-2018, 11:01 AM
MikeMa's Avatar
My only thought, is that there really needs to be some sort of guard. To achieve the angled cuts, the bit seems like it has a LOT more exposure than a typical router table setup as well at an angle we don't typically see router bits at.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #7 of 8 (permalink) Old 12-13-2018, 11:28 AM
Tom in my first couple of pages of uploads is a horizontal setup I made. It was invaluable in making some picture frames my wife wanted, also in those first pages. They were copies of ones we looked at in a framing store that were $25/ft. They required multiple cuts with mostly round nose bits. The horizontal setup allowed me to pass the piece under the bit which meant that the flat back of the molding (I rabbeted it later to accept the print my wife wanted mounted) stayed flat and on the table which gave me the stability I needed to make the multiple cuts. Keep in mind though that if you are feeding under the bit the feed direction is reversed. I found out the hard way.
To me the added stability is the main asset of a horizontal or vertical setup. Either way allows you to work across the face of a piece while leaving the back on the table.
post #8 of 8 (permalink) Old 12-13-2018, 04:52 PM
curiousgeorge's Avatar
First Name: George
Izzy is a genius when it comes to new/different ideas for doing woodworking projects.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is online now
Integrating INCRA : Craftsman Table Saw [TS] & Router Part 3 [ii] Bridged X-cut Box SimonHartropp Jigs and Fixtures 1 10-27-2015 11:50 AM
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
First Router Table Build hankh Table-mounted Routing 9 10-18-2014 10:41 AM
Do I need a router plate for my new table? Ryan's Dad Table-mounted Routing 16 09-16-2011 06:53 PM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 12:21 PM
