Rockler Pro Lift router lift - Router Forums
 1Likes
  • 1 Post By bill.marshall.94
post #1 of 7 (permalink) Old 12-09-2018, 11:34 AM Thread Starter
Jeff Ristau's Avatar
First Name: Jeff
Default Rockler Pro Lift router lift
Hello -
Iím new to the forum. Iím building a router table for my dad using the ROCKLER pro lift router lift. Iíve basically got it all set up but Iím experiencing some issues with the cranking action being extremely tight and rigid. I thought I remembered seeing someone mention a quick fix to this somewhere when researching lifts. Now I canít seem to find that answer, any thoughts are appreciated.
Jeff Ristau is offline
post #2 of 7 (permalink) Old 12-09-2018, 11:44 AM
Originally Posted by Jeff Ristau View Post
Hello -
you don't happen to have the lock on?
Sent from my SM-G960U using Tapatalk
bill.marshall.94 is offline
post #3 of 7 (permalink) Old 12-09-2018, 11:49 AM Thread Starter
First Name: Jeff
Quick response! The lock is loose but I’m guessing it’s something to do with the anti back lash nuts. It cranks up smoothly until about 2 inches from the top and slows to a grind.
post #4 of 7 (permalink) Old 12-09-2018, 11:57 AM
Quick response! The lock is loose but Iím guessing itís something to do with the anti back lash nuts. It cranks up smoothly until about 2 inches from the top and slows to a grind.
maybe that's the end of travel, unless something is binding..sorry can't be more of help.
Jeff Ristau likes this.
post #5 of 7 (permalink) Old 12-10-2018, 06:42 AM
First Name: Larry
Welcome to the forum Jeff.
Knot working is offline
post #6 of 7 (permalink) Old 12-10-2018, 07:16 AM
sreilly's Avatar
First Name: Steve
Welcome to the forum Jeff. My suggestion would be call Rockler and explain the problem. But first make sure the router is fully extended in the lift and look for any unintended contact.
sreilly is offline
post #7 of 7 (permalink) Old 12-10-2018, 03:14 PM
Had one several years ago and sold it. I had problems with it sinking down in use. I think you might not be pushing the router up far enough, and that you may have it so low that you're hitting the end of travel block. If not, and after reading the instruction sheet, consider returning it to Rockler. I used mine with a Bosch 1617 and occasionally had a little trouble inserting the router motor into the lift's jaws. It would bind until I wiggled it and it would come loose so I could push the motor up.
With the lift lowered as far as possible, you want to insert the motor so the bit is just below the plate's surface. That will give you a full range of adjustment. I occasionally cleaned up the inside of the lift where the motor fit. Don't lubricate it!
As much as I liked the idea of the setup, I later switched to a Triton TRA001, which has a built in lift, plus some good safety interlocks. The router didn't cost much more than the Rockler lift. I kept my oldd 1617s for freehand use, so each base has its own motor. Nice.
I built Shop notes router lift paduke Table-mounted Routing 10 01-05-2018 09:06 PM
Inra Lift or Triton Router? Have Incra LS Table Psychbiker Table-mounted Routing 27 09-17-2017 11:54 PM
PRL-V2 Router Lift DarkFlame Starting Off 8 03-20-2011 08:01 PM
