Lining Up Router Bit Without Guide Bearing With Split Fence - Router Forums
 3Likes
post #1 of 12 (permalink) Old 12-14-2018, 09:30 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Lining Up Router Bit Without Guide Bearing With Split Fence
I have a 1/4 round Ovolo router bit with a guide bearing and I've lined it up with the split fence to get the correct cut. I want to remove the guide bearing I've Googled but can't find any information on how to line up a router bit minus the guide bearing, with the split fence?
Thanks.
Gaia is offline
post #2 of 12 (permalink) Old 12-14-2018, 10:05 AM
set the fence to the bearing...
remove the bearing...
reset the fence to your requirements using test cuts and micro adjustments......
post #3 of 12 (permalink) Old 12-14-2018, 04:00 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hi,
I've been watching this post, as there have been no other replies. Then your method must be the accepted way of doing it.
Thanks for replying.
Gaia is offline
post #4 of 12 (permalink) Old 12-14-2018, 04:19 PM
Semipro's Avatar
First Name: John_*
My question to you is why do you need to remove the guide bearing?
Semipro is online now
post #5 of 12 (permalink) Old 12-14-2018, 08:06 PM
What I would do is take off the bearing, line up the fence so that it is on center of the bit both ends. Then move the fence forward 1/2 the diam. of the bearing using the tape settings on the fence readout. Then do a test cut and adjust from there.
Herb Stoops is online now
post #6 of 12 (permalink) Old 12-14-2018, 08:11 PM
I don't know if this will help but when I set a bullnose or other concave profile I use a dowel with equal or smaller diameter curve than the one on the bit. When the dowel sits on both faces and touches the bit you're within thousandths. Most ovolo bits don't have a bearing unless it's on the bit shank.
Herb Stoops likes this.
post #7 of 12 (permalink) Old 12-15-2018, 02:02 AM Thread Starter
Gaia's Avatar
First Name: Peter
I want to cut a deeper fillet.
Gaia is offline
post #8 of 12 (permalink) Old 12-15-2018, 02:34 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Use 1 of these
https://www.trenddirectuk.com/gauge-1
use it upright to gauge the height of the cut, and then use it horizontal to gauge how far away the fence should be from the front of the cutter.
sreilly likes this.
sunnybob is offline
post #9 of 12 (permalink) Old 12-16-2018, 09:24 AM
CharleyL's Avatar
First Name: Charley
If cutting deep, like it sounds like you will be doing, be sure to do it in several passes with the last being just a final light cut.
I once needed to make raised panels for exterior shutters and could not buy a bit that would leave a wide enough tenon along the edges of the panel, because a molding needed to surround the panel and both needed to fit into the dado. I ended up not only removing the bearing from the stock bit, but also grinding off the pin that the bearing had been attached to. This modification allowed me to make the raised panels the way that I needed to, but there was no way to re-install the bearing. The fence position is now the only way to set the cutting depth with that bit. I hated modifying this $100 bit, but the job justified it, and covered the cost of the bit.
Charley
Central North Carolina
CharleyL is offline
post #10 of 12 (permalink) Old 12-16-2018, 09:54 AM
get the correct bit you need in the profile you want...
DesertRatTom likes this.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
how do you set up your fence to be perfectly in line with the Bearing of the bit? hahnsottis Table-mounted Routing 14 08-07-2016 03:52 PM
Kreg Precision router fence #PRS1010 TwoSkies57 Table-mounted Routing 2 06-29-2013 12:45 PM
