What a disaster, need help - Router Forums
post #1 of 11 (permalink) Old 04-11-2009, 07:39 PM Thread Starter
First Name: Todd
Default What a disaster, need help
I started building my router table and everything was going great. I had laminated my top that consisted of 2 pieces of 3/4 mdf. I layed out my router plate and put the guide blocks around it. My guide blocks were 3/4 and 1/4 inch mdf strips taped together. I went around on my first pass cutting a 1/8 deep grove and everything was fine. I then went 1/8 inch deeper around a second time and when I got done, the collar that held my bearing on my router bit came lose and the bearing got above the guide, so I ended up cutting into the guides and made my groove about 1/8 inch wider than it should have been.
Now there were things I should have noticed that should have made me stop, but I couldn't see what was happening because of all the dust that was getting spit out (that should have been a sign).
I'm planning on just flipping over the top and trying it again. Does anyone see any problems with that? I have about a 1/4 inch groove on an 1 1/2 inch thick top.
Todd
taa800 is offline
post #2 of 11 (permalink) Old 04-11-2009, 07:59 PM
AxlMyk's Avatar
Sure, flip it over. You won't be seeing the goof, and you'll have a fresh start.
AxlMyk is offline
post #3 of 11 (permalink) Old 04-11-2009, 08:34 PM
dutchman 46's Avatar
First Name: Howard
I know that it isn't very nice then you run into a problem like this, Is ir possible to glue and screw a wooden edge around the inside edge edge as you would do a finished edge, and reroute a new edge on it. It would look fine, and oak strips would be strong. Does anyone have a reason that it could not be done?
John 3:16
dutchman 46 is offline
post #4 of 11 (permalink) Old 04-11-2009, 08:48 PM
AxlMyk's Avatar
It could be done. Just a lot of work.
AxlMyk is offline
post #5 of 11 (permalink) Old 04-12-2009, 12:03 AM
Ralph Barker's Avatar
First Name: Ralph
I agree - just flip it.
You'll need to put a light in the router well, and a mirror on the bottom so people can see the goof, however.
- Ralph
Ralph Barker is offline
post #6 of 11 (permalink) Old 04-12-2009, 10:31 AM Thread Starter
First Name: Todd
What really frustrates me is that the collar came loose. It seems the bit manufacturer should have a better process to ensure the collar is tight. Or at least supply a hex key with the bit. It's a Freud bit, so it's not like it's a cheap one.
taa800 is offline
post #7 of 11 (permalink) Old 04-12-2009, 11:15 AM
Ghidrah's Avatar
First Name: Ronald
Dutchman, I did something similar on my 1st table top, I had 1/2" strips clamped to the tabletop and 2 of them moved on the final full depth cut.
Had I followed through with your suggestion I believe that my top, (even though replacing the affected area with oak solved the problem) would have looked much nicer.
Axlmyk
As for too much work correcting it, all it took was 2 1/4" strips glued and clamped in the opening, I inverted the template and completed the cut.
Ghidrah is offline
post #8 of 11 (permalink) Old 04-13-2009, 06:14 AM
xplorx4's Avatar
First Name: Jerry
First time I tried had the same problem, so I just cut it even larger and used maple (what I had on hand) and lined the area and re-routed it. Came out fine and works great. I think if I ever do another one, and I will, I may just start out with the liner. Can't find any good pics so I will go down and take one now, back.
Lamentations 3:22-23
xplorx4 is offline
post #9 of 11 (permalink) Old 04-14-2009, 07:14 PM Thread Starter
First Name: Todd
For those that did line the opening with wood, how did you get the strip flush to the table top?
taa800 is offline
post #10 of 11 (permalink) Old 04-20-2009, 08:06 AM
First Name: Howard
The easiest way is to put clamps on each side of the table, Cut the strips and fit them to the edge, 4 screws and 2 strips held to the face side glue the strips with urethane and fit them in right to the hole, bow use a small nailer and staple the edge.
John 3:16
Joke a Day bobj3 Lobby 4071 Today 05:12 AM
Oak bedroom suite mailee Show N' Tell 27 04-25-2009 07:08 PM
